Question about HP Office Equipment & Supplies
Cannot get ahp58 ink cartridge to fit a hp2410 printer,the box that it come in said it would fit; how do I get it to fit?
    President:
  • 1,901 Answers
The #58 cartridge goes into the right side...remove the black cartridge and insert the #58 cartridge. This give the printer a wider range of colors when printing photo.
Posted on Nov 22, 2008
Ran out of ink fitted new cartridge still showing no ink fitted another cartridge still same any clues
If you are using non-original or refilled cartridges, it is common for printers to not acknowledge the ink levels. On most, you have to acknowledge that you are using non-original or used cartridges and then override the ink level sensors. After that, most printers will work. You just won't see ink level monitoring.
Nov 17, 2015 | Office Equipment & Supplies
I want to print some document but the screen in my hp2410 said" remove and check cartridge in right stall.??? what should I do?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | HP PSC 2410 All-In-One InkJet Printer
New ink cartridges fitted, cleaned nozzles but colour still isn't working properly.
Check to see if that kind of cart has a date chip built in to it. HP does that, and I have come across new, out of the box, color cartridges for my 2250 Business Ink Jet, which would not work at all, because their date had expired. Nothing I could do to make them work, but HP was kind enough to trade them for carts that had longer dates, since they realized that I had bought these things and didn't have such a heavy print load that I would use them up before they expired.
Give it a look and see. The date may be on the box, or on the cart itself.
May 21, 2009 | Lexmark X1150 All-In-One InkJet Printer
Will PGI-5BK and BCI-3E ink tanks fit in the MX700?
Ink Tanks:
PGI-5BK, CLI-8C/CLI-8M/CLI-8Y
According to the canon australia website these are the inks for the MX700
Feb 20, 2008 | Canon MX700 Office All-In-One InkJet...
Really really slow printing!
I had the same problem with a hp 4315 it was a bad ink cartridge causing the problem. It did the same for a different hp printer.
Feb 19, 2008 | HP DeskJet 670c InkJet Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
43 people viewed this question
Ben Johnson
