Question about Toshiba CZ32V51 32" TV
Remote doesn't work
I have a Toshiba CZ32V51. Up until the last few weeks it has been great. I've moved it several times and never a problem. Recently the remote stopped working. I tried two universal as well as they don't work with the TV. I'm guessing whatever on the inside that accepts input from the remote died. Any idea's on fixing this?
  • 38 Answers
Here's a tip to test all remotes
point it at your digital camera/webcam
although the human eye cannot see infared, your camera lense can
watch the monitor to check if its flashing.
also - if you have moved the set, perhaps something inside - such as a wire loom - has fallen in front of the infa red reciever? or it may just need the window cleaning
Posted on Nov 22, 2008
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Jul 01, 2012 | Toshiba Computers & Internet
2004 Chevy Cavalier - car cranks over but doesn't start
Ignition module or crankshaft postion sensor . Test it in the vehicle , test light , volt meter . Videos on youtube .
2004 Saturn Ion 2 2 Misfire Case Study P0300
Mar 25, 2017 | 2004 Chevrolet Cavalier
Back box on bottom 1/2 of screen happened a year ago. Can' remember what to do. Help I have big Toshiba CZ32V51 with universal removte Phillips
Can u get into ur tv menu with the universal remote?If u can't tries it with the tv manual buttons look at on the botton of ur tv have manual button said menu.Press it go into the tv menu.Look inside the tv menu for functions like Close Caption like CC1,2,3 and Text 1,2,3 make sure all CC1,2,3 and Text 1,2,3 turn it to all off.Black square box will disapear.Can't do it in the tv manual button etheir.Try website like Remote.com to buy the tv origial remote to close Close Captioning and Text 1,2,3 to all off.
Apr 15, 2011 | Toshiba CZ32V51 32" TV
My neighbor has a toshiba dvd/vcr player and until recently was working fine, she says the vcr works fine but when she wanted to view a movie on the dvd side a message came on the screen - not correct disk...
yes deffenitly DVD CD lens cleaner is acvilable in the market. You can try it and i hope the problem will be sort it out. You have not mentioned that where you put up.
Alexander
India (Delhi)
Apr 11, 2011 | Toshiba Televison & Video
When I purchased this remote control a few weeks ago, I programmed it and it worked great! a few weeks later, it stopped working. So, I re-programmed it again. Will I need to re-program this remote control...
I would suggest contacting the Toshiba MR 120's manufacurer or the dealer from whom you bought it. Either one will likely exchange it for one that works if it's discovered that the problem is in the original manufacture, or they will check for programming gliches and fix the ones that exist. Either way, your remote should not be behaving that way, and one would like to think that a quality brand name like Toshiba will stand behind their products.
Feb 21, 2011 | Toshiba MR120 Remote Control
The hand held remote will not work for my toshiba tv (model #cz32v51). I put fresh batteries in and that did not help. Bought a universal remote and that did not work. There must be a remote receiver...
its batter in a shop were spares can be found. in side a tv there is a photo senser which converts light into electrical signals.
let the photo diode be tested
and also the remote you have on other toshiba sets to confirm, if remotes are a problem or not.
remotes have codes to change to another remote, 060, 019, 014, 052, 059, 075.
Apr 01, 2009 | Toshiba CZ32V51 32" TV
No pic, no sound
Hey Wilt: We had the same problem, for the same model of Toshiba TV. Had it repaired yesterday. Turns out the problem was the power supply (P.C.B). The total cost was $192.66 Canadian funds (taxes and labour all in). Our model was 6 years old, buts its playing like a brand new unit now. Hope this helped ...... Good luck
Oct 26, 2006 | Toshiba CZ32V51 32" TV
Toshiba 53H71
Your Television is going into protection shutdown. More than likely the problem will be sweep related IE Convergance is the most likely culprit your best bet is to have a technician look at it
Aug 27, 2006 | Toshiba 53H71 53 in. Rear Projection...
Toshiba CZ32V51 32" TV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
