Question about Whirlpool RBS245PDS Electric Single Oven
Oven will not work on my whirlpool rde350pw1
I ran the power lines to my brother-n-law's oven and all are hot but the oven and broiler will not come on. I am almost leaningf to my timer but that shpuld not affect the broiler/oven if I have the timer off. any suggestions? A.J.
  • 306 Answers
Sounding like the element is bad for the oven. Can you ohm it out? If that checks okay then it is diffidently the knob to turn on the oven. The switch is bad and needs to be replaced.
Posted on Nov 26, 2008
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Pieces of my broiler element in my oven actually fell off. How do I replace the element?
Disconnect the power to the stove. L-2 is always hot straight to the oven elements. Rub the element against the hole in the frame and you will be buying another new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2011 | Whirlpool Ovens
Broiler element and oven element not working. oven has power to it, all lights and displays are working,
Since neither the broiler or bake elements are working I would suspect either the sensor - sensing a higher temperature than set meaning the sensor is defective (Item #29 on the diagram) - http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Wall-oven-Parts/Model-YRBS305PDB5/1198/0125300/W0703198/00001?blt=06&prst=&shdMod=
You might try the self clean function and see if the elements get hot. If they do then it is most likely the sensor.
Hopefully, that will fix your problem, but if not then it could be in the microcomputer which is a problem because it is a part that is hard to find.
Sep 04, 2011 | Whirlpool RBS305PD Electric Single Oven
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Whirlpool RBS245PDS Electric Single Oven Logo
113 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
