Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Having trouble connecting to another console on the router
Im having trouble connecting to a console called x box 360, i tested my connection and its connected to the network adapter, but it is not connceting to my IP Address. Its saying on my console that it cant negotiate a lease on the DCHP Server, and have a valid IP address. I called microsoft and they couldn't help me. So if you guys got any facts or if you guys know what the problem is, please let me know i want to go online on my Xbox please and thank you.
    Problem Solver:
  • 5 Answers
You have to configure your dlink router to run with the xbox 360. Go to the dlink website and follow the instructions on configuring your router.
Posted on Jan 11, 2009
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
My xbox 360 wont connect to xbox live and ive tried everthing
things you can do..... first start by connecting your 360 to the router and run a test through the system setting menu on your 360 dash board.... to do this go to system setting menu and select the network setting menu.... after selecting network setting there should be an option to test you`xbox live connection.... this is the first step in trouble shooting.... if your xbox connects to the network or router than the problem may be in the Internet connection.... after you have a connection between the xbox and the router... connect the router to the Internet and run the the test again... if you are connected to the network and the internet but still not to xbox live try doing a system update to update your system with xbox live.... after doing all of these steps you may have purchased and xbox that has been banned from xbox live and will not be able to join xbox live..... a more simple solution is that you may not have an xbox live account and simply need to set one up... this can be done through the xbox or you can go to www.xbox.com and set up a live account... you can also find FAQ's and trouble shooting steps there
Apr 22, 2010 | Microsoft Xbox 360 Console
Connection Interrupted on Xbox Live with COD
To me it sounds like you are having a DSL problem. If you are not up to calling your ISP for a trouble call, try playing at a friends house with your console and see if the problem happens there also. If it has no problems, then you know your console is not the culprit. You could also try connecting directly to your modem and bypassing the router for testing purposes. If a direct connect to modem works, then look at your router.
Linksys is PnP with Live. You should not have to open any ports. If you get to the point during troubleshooting that you know for sure it is your router, reset it to default settings.
Sep 07, 2009 | Microsoft Xbox 360 Console
I HAVE SUDDENLINK AND IM TRYING TO GET CONNECT TO XBOX 360 LIVE
Well you need a modem to connect you're console to the internet. call you're company and set up your modem, sometimes you can actually get a modem from your company directly. then you plug your x box into the modem and let them establish connection for a minute( just let them sit, it should be automatic) then go to test x box live connection on your xbox, it should be in settings and then network.
Feb 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Call Of Duty 4 Connection,
Yea, if it is wirelessly connected to the router, and all the tests pass, it should be working ok. I would call xbox live customer support, they probably have helped many people just like you with this problem.
May 28, 2008 | Microsoft Xbox 360 Console
I am trying to connect my xbox 360 to the internet. but when I instantiate the test connection it says that the IP address failed. I have my x box connected to a router, with a stable internet connection....
Hi there, there are a few different things you can try, but the easiest is to set up your IP address manually.
There's a very good guide to how to do it (along with trouble-shooting tips if you have further issues) here.
Apr 15, 2008 | Microsoft Xbox 360 Console
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
