Question about HP PSC 1210 All-In-One InkJet Printer
Printer says out of paper. paper added still wont print
Hi
I have a HP 1210 psc. It currently says that is is out of paper and it therefore will not print. I have since added more paper but it still says their isnt any. And it obviously works b/c I can scan stuff. how do I change the setting so it recognizes the paper?
thanks
  • Anonymous Dec 10, 2008
    yeah i got the same problem
  • peekaboo123 Feb 15, 2009
    I had the same problem and had tried everything. Then I read the suggestion of restarting the spooler. I knew that was the problem, but had no idea how to restart. So easy! Thanks for your help.
The solution to this is bizarre but worked for me.
In Vista press the windows key and R button. The Run window opens and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which opened in the previous step.
3. Right click on it and select Restart.
Your printer will print a self-test page but then should be good to go.
Posted on Dec 14, 2008
Online support from the HP website was all I needed. they were great, it was an involved process that i wouldnt have figured out myself
Posted on Nov 23, 2008
I have a hp psc 1210 all in one printer that keeps telling me its out of paper ,added paper but still
wont work.
jaxintle.
Posted on Nov 27, 2008
Paper wont feed on my hp psc 1210 all in one printer
open the door at the back of the printer and clean the rollers.
Unplug the power cord at the back of the printer while it is still on and then after 30 seconds plug it back in.
If it will still have the same problem then there is a problem with its sensor.
Good Luck!
Jul 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
My HP laserjet 3600N wont print it says its out of paper but its not. Have taken paper out, added new paper, put less in, put more in but still says out of paper - any ideas please
The problem is underneath tray 2 - there is a plastic tab that sits on a metal crossmember that engages the paper tray to "pop up" when you insert the tray . If you bend that cross member up that has the plastic tab it will engage the tray and let the paper been seen by the sensor. There must be a better Hp fix but have not found it yet.
Mar 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
I just installed my 1210 all in one HP printer, its used and i havent used it in a while, it had an error message by the ink cartridge light so i had to put in new ink cartridges now it will do anything...
HI,
DEAR TRY COPY A PRINT i mean print out not from your system jast put a paper in to your secner and copy it if the printer do it.then reinstall your software
if not then you have to repair it from your nearest printer repair shop.
Dec 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210
HP PSC 1210 software wont work with vista. That is the software that comes with the printer containing photo disk ,toolbox etc. HP tells me to get a new printer but its the program that needs attention.
Apr 29, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer wont print
Not sure but this printer may not be compatable with vista. OR.... you say it goes through the motions, does a page of paper come out? Did you try a different cartridge?
Aug 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
3,018 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
