Question about Pit SSR 110CC Pro Beginner Bike
Gears i have a 110 pit bike and it wont select gears ,i have took the gear casing off to have a look but cant go any further can someone help please
It needs new gears mate
Posted on Nov 27, 2008
I have 125cc xtreme pit bike and when I'm riding
Apr 30, 2014 | Motorcycles
Cant change gear
Clutch worn or cable to slack or tight or gear box is smashed
Mar 10, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
200cc pit bike wont go in first gear? some one help me please
sounds like your shift lever may have been put back on in a different spot on the shift shaft. make sure it can move up and down with out hitting anything.
Sep 21, 2017 | Suzuko Motorcycles
My chain has gone to tight and it locked in gear
Try rolling the bike back and forth while trying to take it out of gear if this doesn't work ur clutch has brine burned out and ha s locked ur gears up but this one would be the last thing to check once u have tryed rolling it.
Aug 12, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
Engine wont start but is turning over i believe. gear shifter broken and jammed in first or second gear.
Hi Alex Iam not too sure but I think this model had a neutral switch fitted that stopped the bike from starting in gear , and displayed a light on the clocks when the bike was in neutral .
If as you say the bike is jammed in first this is probably the cause
the jamming sounds abit more serious ?.. you may have bent the selectors and this will mean a gearnox stripdown , it is even possible you have damaged the lay shaft if the bike was travelling when you came off this would also mean a box strip down .
I dont think there is an easy answer to this one Alex loks like you will have to take the engine apart to fix this one ( one thing did strike me I had an old BSA that I slid on the gear shaft and did the same thing stuck in first turned out I had bent the gear shaft removal of the pedal and gentle tapping freed the gears off and I was able to use the bike again ? it may help I cant be sure be careful not to damage the case or the splines I used a small lump hammer and a block of 4x 4 against the shaft .. I also put a wedge behind the shaft to stop damaging the rear of the box housing ) hope this helps Regards vortash
May 11, 2009 | 2007 Harley Davidson XL 883 Sportster
My motorbike wont go into 3rd,4th,5th and 6th gear
make sure your foot is not holding the gear selecter after changing into second while riding as this would not let the bike go any higher through the gears
Feb 22, 2009 | 2007 kawasaki Z750
Pit SSR 110CC Pro Beginner  Bike Logo
394 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
