Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Understanding how to use spa with freeze protection on
We are living in a new home that has a system where the pool and spa are connected to the same filter ump. Freeze protection is activated n both due to freezing to subfreezing temps. QUESTION: HOW DO WE GET TO USE THE IN GROUND SPA IN THESE CONDITIONS?
We have the RS4 Aqualink System.
When I push the spa button, the screen says "press enter to override freeze protection or abort" IF I DO THIS, WILL POOL LOSE FREEZE PROTECTION WHILE USING THE SPA? HOW DO WE GET FREEZE PROTECTION BACK ON TO BOTH POOL AND SPA when we are done using the spa at 104degrees
IS IT OK TO USE INGROUND SPA DURING WINTER MONTHS? IS KEEPING THE FILTER ON ALL THE TIME AND THE SPA HEATER SET TO SOMEWHERE BETWEEN 50-60 (IF POSSIBLE) WHEN WE ARE NOT HEATING IT TO USE THE WAY TO GO? DO YOU HAVE ANY IDEA IF THIS IS REALLY EXPENSIVE?
We are pool novices. It is unusually cold in PA right now. Also we really want to be able to use the spa in the winter because one of us has serious back and muscle problems.
ANY HELP YOU CAN OFFER WILL BE GREATLY APPRECIATED AND USED! THANK YOU IN ADVANCE
I have been told by Sylvan that there is a relatively simple way to separate the two systems by adding some sort of valve....?
    Problem Solver:
  • 7 Answers
Freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Posted on Jan 06, 2009
The hot tub drains when the freeze protection engages at 35 degrees
It sounds like the suction side valve is out of place, it may need a new blue aviator or the existing one may need to be adjust so it is not sucking from the spa and returning to the pool which will cause your spa to drain.
Jan 01, 2015 | Jandy Pool & Spa
Compool cp3600 control panel freezing temp adjustment
system set up freeze protect highlight what you want on
Feb 16, 2014 | Pentair Compool CP3600TLX Pool & Spa...
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do i remove freeze protect from my hand held device
go to system set up find freeze protect any aux that is checked un check and that will un freeze protect it
Dec 10, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
How do I remove item from aqualink rs4 freeze protection
go into system setup go to freeze protect un highlite what you dont want to go on
Feb 01, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Usig/overriding freeze protection on a pol/spa filtering system
Any entry into SERVICE mode from the outside panel will override a freeze protect. Be sure to put it back to AUTO in order to resume freeze.
Nov 24, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
409 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
