Question about Singer 7468 Mechanical Sewing Machine
Singer sewing machine 7468
When I turn in the machine on it just gives me a beeping sound and will not run. Whant do you think is wrong with it? I was using it fine and all of a sudden this occured. I have checked evrything to no avail. The machine is on;y 2 months old. Thank you.
  • Anonymous Mar 25, 2008
    i am having the same problem, it seems everytime i move my machine the 7468 and turn it on it has lost its mind. all it does is beep and flash 88 in the display window. when i called my dealer she said to turn it off and give it time to reset its self.
SOURCE: Unable to sew straight stictch with singer futura ce 100
When I had this experience I cleaned the thread path under the plastic cover. There was a piece of thread caught between the disks.
Posted on Aug 15, 2008
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
  • 240 Answers
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Posted on Jun 11, 2009
  • 1788 Answers
SOURCE: how do I replace the lightbulb in mu singer model
I looked at your manual and I don't see it listed. But, I would call Singer at 1-800-4singer customer service and ask, that is very strange. I think you may have to pop off the little white cover and loosen the screw on the top side of the machine, but I am not sure. Call them, they are very helpful. Good luck
Posted on Oct 27, 2010
  • 1788 Answers
SOURCE: when sewing curtain fabric together
I looked at your manual (www.singerco.com, customer service) and page 82 gives some good suggestions on tension, I usually use 3 or auto, then you stitch length may be too long. I ended up using metal bobbins on my machine because the plastic ones seemed to jump too much for me. I am not sure if your machine takes a 15 or 15J bobbin. If it is the 15J, I know that a SA 156 does the trick for me. I hope that will help you in some way. If not, call Singer at 1-800-4singer and ask them. . Good luck
Posted on Dec 08, 2010
I can not turn the wheel to fill my bobbin. And the needle keps trying to sew and after awhile the safety beep comes on how do I fill it.
1. Read and understand your manual. The days of turning a wheel to disengage the needle are pretty much LONG GONE.
2. Put your bobbin on top of the machine where it goes and slide it to the left. This action disengages the needle.
Mar 15, 2013 | Singer 7468 Mechanical Sewing Machine
I have a singer 7468. THE BOBB IN CASE KEEPS POPPING OUT. CAN THIS BE FIX?
the sewing machine may need a new bobbin case,, but I would
suggest take the sewing machine to a repair shop to see if there
is something wrong with the hook & hook race,,that may be why
the bobbin case is coming out.
Oct 06, 2012 | Singer 7468 Mechanical Sewing Machine
Singer 7468 birdnest issues
:) If you are nesting below the fabric and in the bobbin area... that is an upper tension problem. Tighten the upper tension... and try again.
Aug 31, 2012 | Singer 7468 Mechanical Sewing Machine
When sewing curtain fabric together (main fabric and lining) it seems like the bobbin is just bouncing all over the place. The fabric is puckering, the top stitch looks like a basting stitch. I have a...
Dec 08, 2010 | Singer 7468 Mechanical Sewing Machine
How do you change the light bulb on the 7468 model sewing machine.
I look on the singer website it has a free operation manual of your sewing machine
just put in the model number & it brings it up it's the second one
Nov 27, 2010 | Singer 7468 Mechanical Sewing Machine
How do I replace the lightbulb in mu singer model 7468?
Oct 27, 2010 | Singer 7468 Mechanical Sewing Machine
I push the peddle down and all I get is beeping what is wrong with my 7442 singer
I would call Singer at 1-800-4singer and find out. I looked up your manual at www.singerco.com for free and don't see any mention of a beeping sound except on page 28. Your machine is a computerized one, not mechanical.
Oct 21, 2010 | Singer 7442 Mechanical Sewing Machine
Oct 31, 2008 | Singer 7422
Singer 7468 Mechanical Sewing Machine Logo
47 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
