Question about Verona 34 in. CTG536S Gas Cooktop
I HAVE A CORNING COUNTERRANGE, PRE 1973. IT HAS PERFORMED WONDERFULLY ALL THESE YEARS, BUT NOW THE OVEN THERMOSTAT DOES NOT WORK CORRECTLY. THE OVEN LIGHT TURNS OFF BUT THE ELEMENT DOES NOT....SO THE OVEN CONTINUES TO GET HOTTER AND HOTTER. I CANNOT READ THE MODEL NUMBER ANYMORE. IS THER ANY CHANCE THAT I CAN GET A THERMOSTAT FOR THE OVEN CONTROL?
  • patriciamcel Dec 08, 2008
    i have a corning 3+1 counterrange. I think the thermostat is not working.
    i will set the oven at 350 and it will get well over 400. how do i check if i need a new thermostat. Can i replace the thermostat myself?
    Sergeant:
    Champion:
  • 338 Answers
No if you do not have a model number you cannot get the parts. no service company will help you either.
Posted on Nov 26, 2008
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
My stove top works but oven and broiler will not heat
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
Feb 16, 2015 | Frigidaire Stove / Oven / Range Glass...
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
I have a 37 year old 3+! corning range which I love. The oven heats between 25-50 high..Help!!
This sounds like replacing (or if possible - adjusting) the thermostat will fix the problem. Fortunately, thermostat technology hasn't advanced to the microprocessor level yet, so you (or your appliance repair person) should be able to find a workable replacement - assuming it isn't a real odd-ball.
Some thermostats allow for minor adjustments - but not all. Since I have no idea which oven you have - there's little more I can provide.
Oct 09, 2013 | Verona 34 in. CTG536S Gas Cooktop
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
Can you use metal cookware on the old Corning Glasstop ranges? If not, what do you recommend?
Yes. I use metal pots and pans on mine for years. They need a flat bottom. Heavey bottomed pans work best - Thin pans don't transmit the heat well,
Mar 09, 2011 | Verona 34 in. CTG536S Gas Cooktop
I HAVE A CORNING COUNTERANGE. I THNK WE BOUGHT IT AROUND 1973. IT HAS BEEN A WONDERFUL APPLIANCE ALL THESE YEARS....BUT NOW THE OVEN THERMOSTAT DOES NOT WORK PROPERLY. THE OVEN LIGHT TURNS OFF BUT THE OVEN...
YOUR ADVISE DID NOT POSE A SOLUTION TO MY PROBLEM. I THINK YOU SHOULD REFUND THE TWENTY DOLLAR FEE YOU CHARGED ME FOR LESS THAN FIVE MINUTES OF "CHAT". NEITHER OF THE WEB PAGES HAD ANY HELPFUL INFO. WHAT A RACKET YOU HAVE GOING!
Nov 22, 2008 | Verona 34 in. CTG536S Gas Cooktop
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Verona 34 in. CTG536S Gas Cooktop Logo
430 people viewed this question
Top Verona Cooktops Experts
Steve
Bosse Photos
Pierre Legault
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
