Channel changer keep constantly changing channels
  • 13,433 Answers
The button maybe stuck, if you mean the remote controller, try removing the batterys and see if it stops, if it doesn't stop you possibly have a stuck button on the television or possibly a fault which is doing this.
Posted on Nov 22, 2008
    Brigadier General:
  • 3,614 Answers
May i know the exact model / maker of your tv..?
  • micromaster
    micromaster Nov 22, 2008
    check all connection of yourtv.
2 Suggested Answers
  • 1779 Answers
SOURCE: I have no front control panel working and changes channels
The front controls are called Tac Switches. They have a tendency of becoming corroded and sending erroneous commands to the micro. You can disconnect the lead coming from the control panel to the chassis and see if it quits. If it does, that answers your question. If you decide to replace them all, try Encompassparts.com
Posted on Jul 15, 2009
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
Tv keeps changing channels
Do a reset to this TV and check. If it do not help you, replace its main system control memory IC. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | Beko Televison & Video
Tuner appears to be stuck in channel 4. Cannot change Channel.
It is a tuner selector problem, either the processor controller ic is the problem, or the selector ic. The easiest solution use a VCR as your channel changer, and check to make the VCR is set to channel 4.
Jan 03, 2011 | Panasonic CT-27SL14 27" TV
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
PRESET STATION CHANGER WILL NOT ALLOW CHANGING ON 2001 ASTRA
Seems to have cleared up, just cleaned the pins on the back of the removable unit
Nov 24, 2009 | Car Audio & Video
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
Channel changer locks up
Make sure you have the tuner set for digital channels only. then redo the channel search.
May 06, 2017 | Hitachi 57F500 57" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
