Question about HP Office Equipment & Supplies
My pc is telling me that i have a problem with one of my cartridges. I have tried everything i am supposed to do, and nothing works. The orange light beside the off/on is continually flashing and there is nothing i can do to fix the problem.
  • 38 Answers
Change the cartridge?
Posted on Nov 22, 2008
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
HP Compaq dx2000 Microtower PC not starting up properly, the orange light keeps flashing on the front and nothing on the monitor. Tried unplugging everything, depressing button for 5 seconds...nothing...
Are you sure it's not red you're seeing instead of orange? Disconnect power. Re-seat the RAM circuit boards inside the computer. Check for possible loose parts inside. Check all the fans and remove accumulated dust. Check the CPU - if possible remove the heat sink and inspect the silicone compound for dryness - reapply new compound if it's dry. The power supply may be bad as well - check that.
Nov 11, 2010 | HP Compaq dx2000 Microtower PC Desktop
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Document is not printing
    Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
    Feb 03, 2009 | HP DeskJet 932c InkJet Printer
    Samsung CLP-300
    Open all the covers and close all of them , See any changes if not remove the toner cartridges and see any paper jam in the tray or else. If nothing works out see any sensor is broken physically and update me.
    Feb 27, 2008 | Samsung CLP 300 Laser Printer
    Orange light
    The orange light is for you to know that the plastation2 is working unless it is not reading the disk then you etheir take it back or tip it over on its side then let it do the rest or if that dont work then it either broke or if you get it to work then you are alright at games.................. thats all the info i have on that........ there you go.
    Jan 24, 2008 | Sony PlayStation 2 Slimline Console
    Link light on the modem green or orange
    the first 4 lights should be gree then the fith orange and should be flickereing on and off fast the last one should be doing nothing
    Nov 23, 2007 | Arris SURFboard SB5120 Modem
    Getting "E" error icon with orange light flashing above by ink drop icon
    click on start, then click run, type in the word services.msc, you will then get a list of options scroll down the lost to the letter p and find the word print spooler. click print spooler once then in the left corner you will have to options, either to stop or refresh, before doing anything take the usb out of the back of the printer, then click on stop, then click start, then click refresh, after this put your usb back in the printer, and that ''should'' solve the problem. email me if works or does not, thanks
    Oct 03, 2007 | HP DeskJet F380 All-In-One Printer
    18 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
