Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley davidson won't start
Have changed battery, checked everything and was wondering how to troubleshoot my starter and solenoid.
Thanks,
Kay
This is a new starter and solenoid
Thanks anyway but I fixed it low battery
Posted on Dec 15, 2008
    Problem Solver:
  • 6 Answers
Test for power to the solenoid when you push the starter button. This should help to eliminate the switch, relay,wiring etc. You can also run a jumper wire from the large (power) cable on the top of the starter to the green wire on the white connector on the end of the starter.
Posted on Nov 23, 2008
2009 Harley Davidson Softail Fat Boy won't start clicking sound
Hi, Foe before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Relay clicks but won start
Harley Davidson Softail Workshop Service Repair Manual 2009 $8
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2009-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Aug 13, 2017 | 2009 Harley Davidson FLSTF Fat Boy
2009 street glide battery good fuel good ... push button to run push start switch nothing happens. it is in neutral,all electrical works
Hi, M before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
8. Faulty kickstand or clutch pull in switch/sensor.
10. Starter relay, solenoid or starter circuit wiring faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Ultra Classic won start no sound nothing Harley Davidson Forums
Harley Davidson Touring Workshop Service Repair Manual 2009 $8 very cheap
Instant Tech Relief To speak with me personally absolutely "FREE"
Apr 03, 2017 | 2009 Harley Davidson FLHX Street Glide
2010 harley ultra turn signals flashing won't start?
Hi, Roger start with # 5 otherwise the usual suspects are:
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Bike won start Security System Twin Forum Harley Davidson Forums
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Jan 01, 2016 | Ultra Motorcycles
Why won't it crank?
Hi, Robert and the usual suspects are:
Harley Davidson Softail Won Start
harley davidson wont start after fall
Dec 12, 2015 | 2000 Harley Davidson FLSTC Heritage...
Removed battery. Replaced starter. Reinstalled battery. Why is there no power anywhere?
Hi, Bruce you may have a faulty main fuse otherwise the usual suspects are:
Testing the Battery and Charging System Harley Davidson FXSTC
Harley Davidson Won Start But Cranks HELP
How to diagnose no spark situation on motorcycle
Harley Davidson Softail Won Start Harley Davidson Manuals Mark Workshop
Dec 04, 2015 | Harley Davidson FLHTCUI Electra Glide...
Harley sportster ignition relay test won't start
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Apr 13, 2013 | Harley Davidson XL 1200 S Sportster Sport...
1978 Harley Davidson FXS solenoid clicks
Hi, Michael you turn on the ignition switch press the starter button and all you get is the dreaded "CLICK" now before testing any electrical component in the Starter System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries and the usual suspects are:
1. Battery terminals have loose or corroded connections.
2. Battery cables faulty due corroded or broken internal wiring at the cable connector especially the "NEGATIVE" cable which needs to be checked at "BOTH" ends.
3. Battery voltage, must be 12.5 volts or better, voltage from the battery to the main circuit breaker to the ignition switch to the security/ignition fuse to the TSM/TSSM module to the engine stop/run switch to the starter button to the starter relay to the green wire that connects to the starter solenoid must not drop more than 1/2 volt of battery voltage.
4. Disconnect spark plug cables, with a voltmeter connected to the battery, the ignition switch in the on position, the kill switch in the run position, the starter button depressed, starter engagement should not bring voltage below 9.6 volts DC. If the voltage is below 9.6 the battery is faulty and must be replaced. I "HIGHLY" recommend a maintenance free AGM battery typically they have more amperage for cranking.
5. Faulty starter relay, check continuity.
6. Faulty starter solenoid, check contact plate and shoes for excessive electrical erosion/etching, refurbish as necessary or invert contact plate and use the virgin backside. Check contact shoes for being loose. Replace solenoid if the negative function is still a final outcome.
7. Faulty starter, bench test starter with a 12-volt battery if negative function check, decontaminate and undercut armature commutator segments as necessary, check segments with an ohmmeter probe each one and the segment next to it for shorts. Have the armature tested with a growler and field coils, and brush plate with an ohm-meter for opens, shorts or grounds. Replace brushes if less than .438" It is generally cheaper to overhaul/refurbish a starter motor than buying a new one.
1980 shovel head relay clicking starter won engage Harley Davidson Forums
https://www.carlsalter.com/pdfs/Harley-davidson-1978-80%20FL_FX%20Service%20manual.pdf
https://www.rockymountainatvmc.com/Parts-Finder/7232/1978-HARLEY-DAVIDSON%C2%AE-Super-Glide-Low-Rider-Shovelhead-FXS-%C2%AE
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Sep 15, 2017 | Harley Davidson Motorcycles
Starter replacement 2007 Harley Davidson flstc Heritage Softail
Hi Anonymous, before you start throwing big money away start by throwing small money away. First make sure your battery is fully charged, then do a load test anything below 9 volts replace the battery. Second replace the starter relay cheap $6. Third remove the back cover of the solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. Fourth make sure the starter drive/clutch only spins one way. If everything checks out ok then you can start throwing big money at it. Good luck
Aug 09, 2012 | 2007 Harley Davidson FLSTC Heritage...
Won't start
Hi Dougiet, and the usual suspects are:
3.Discharged battery, loose or corroded connections check negative cable at BOTH ends. (solenoid chatters).
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jun 17, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
Engine won't start. battery just recharged. no sound when starter button pushed. all lights, signals and horn work.
Hi Vegaskeith, and the usual suspects are:
3.Discharged battery, loose or corroded connections check negative cable at "BOTH" ends. (solenoid chatters).
For a prime suspect please visit website below. Good luck and have nice day. Codes 1130cc com The 1 Harley Davidson Rod Forum
Sep 08, 2011 | 2008 Harley Davidson VRSCD Night Rod
Lands Phones Logo
800 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
