Question about Mitsubishi WS-65819 TV
Turns off as soon as I turn it on. ws - 65819
Working fine yesterday ,last nite while it was on it powered down and when I hit power to turn it back on it shuts down after couple of seconds. Green light comes as will. If that means anything.
I have looked for cold solder points or lose points nothing and anything that looked ? I went ahead and resoldered.
Any help would be great.
  • 1 more comment
  • redmaxim Mar 08, 2009
    check fuse and and good. what's next?
  • Anonymous Mar 22, 2009
    The TV turned itself off after some weird convergence issues. Now, when I hit the power button, the green light comes on for no more than a couple of seconds and the TV turns itself off.
    The problem is that one or both of the integrated circuits that controls convergence have gone bad, and probably burned out one or more of the fuses on the board.
    I had a repair man out not more than two days ago. He replaced both ICs and a couple of fuses. The TV worked fine for two days. Today the convergence went weird, and the tv turned itself off again. Hopefully, they will stand behind their $600 repair bill. If not, I'll be happy to post their info and my experience.
  • mammy0155 May 24, 2009
    MY WS-65819 IS DOING THE SAME THING.DO YOU HAVE TO GET A REPAIRMAN TO FIX OR IS IT POSSIBLE FOR ANYONE TO REPAIR.
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Posted on Mar 22, 2009
Mongotron does your tv work now... i have that same problem
Posted on Oct 18, 2011
  • 27 Answers
Check for bad fuses on pc board also may have a bad crystal
Posted on Dec 12, 2008
My ws-65819 turns on but turned off quick. if there's a reset, where?
Posted on Mar 08, 2009
Mitsubishi Medallion WS-65819 wont turn on. Code 2-2
The power supply regulator section circuit inside should be troubleshooted.
Mar 28, 2013 | Mitsubishi WS-65819 TV
Have a Mitsubishi WS-65819 (about 9 yrs). over past 3-4 weeks the color started to skew (3D like arch on top and bottom), then yesterday, the TV totally powered down and will not power up, totally dead. ...
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Aug 09, 2011 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
My Mitsubishi ws-65819 won't power up. When I use
Unplug it ,leave it unplugged for at least an hour.
now slowly plug back in , if you notice a small spark coming
from the plug when you plug it in that's normal
which means most likely the regulator or output tran is out.
is about 150.00 200.00 normal cost. no more.
If the plug doesn't spark at all when you plug it in slowly
could be a Fuse :>
Jun 28, 2009 | Mitsubishi WS-65819 TV
Intermittent convergence issue became permanent
Hi Ed,
Your convergence amplifiers are definitely bad. The user manual will not work, since it is the same manual that comes with the set when it was new. The service manual can be found at:
http://servicemanuals.net/results.aspx?type=SM&brand=0&model=WS-65819
Best Regards,
MyTvGuy
P.S. Thanks in advance for rating me!
Feb 09, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Nov 30, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Problem
it the circut board that is connected to the power cord ,
Nov 26, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
584 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
