Question about Nintendo GameCube Console
Disk read error
While playing on his gamcube, my son will get the "disk read error" during the middle of the game. This occurs on both old and new disks. Any suggestions?
  • Ray Clark May 08, 2007
    One additional thing we have noticed is when we get the read errors the disk has stopped spinning. Opening and closing the case starts it back. Would that still be a cleaning or POT issue
  • Anonymous Mar 20, 2014
    When try to play game error appears on screen
    Problem Solver:
  • 7 Answers
I had that problem 2 for a while, all you have to do usually is clean the reader with a good lens cleaner, you can get them for like $10 at a glasses store, i would recommend buying one if you have allot of disk readers that you have problems with. The other thing to do is to check to see if the reader is jammed, that can be a real problem, just wiggle it and it will come lose. Before playing move the reader to the outside of the disk slot, close the case, turn on the GC and then once the menu comes up go to the play game selection at the top of the cube like menu and select it, then insert the game and close the lid, tell it to play and its almost garenteed to work, if not you need to get it or the game you are trying to play fixed.
Posted on Jun 13, 2007
    Problem Solver:
  • 14 Answers
The problem could be that the lens is waring out... not problem though, this can be fixed quite easily (if it salvageable, that is, and that it hasn't degraded too much..) There is something called a POT of the lens, which is basically the power and spread the laser uses to read discs.. over time, its figure reduces, and if it reaches too low, or beyond a certain point, it could render the lens and machine useless.. if you want to try, you can open up the machine to tweak the POT level.. which is in no way harmful if you adjust it within reasonable limits... Here is a guide to doing it, and what will be required, if it seems to be the only option you have left... http://modthatcube.pxn-os.com/content/pot.htm I'd personally recommend adjusting the POT once in a while anyways, for maintenance, and once you do it once, will only take 5-8 minutes each time.. I've also noticed that stuff loads faster since I adjusted mine..
Posted on Apr 30, 2007
Get some canned duster spray and spray the holes on the side of the gamecube
Posted on Apr 15, 2007
Poen and close the lid
Posted on Mar 12, 2007
  • 24 Answers
Try running a CD Lens cleaner through the machine, Special Gamecube cleaners are available.
Posted on Dec 31, 2006
My son was playing his newly internet connected game black ops, in the middle of the match it said error on disk please eject disk and turn off console. He ejected the disk but the console would not turn...
This sounds like an error with the console that would need a repair from Nintendo. You can send the console to them in order to get it fixed. This usually takes about a month.
If you are more adventurous, however, there is a great guide I will link below that will help you correct the problem yourself. Warning, though, it should not be attempted unless you know what you are doing.
http://hubpages.com/hub/wiidiyrepairguide
Mar 06, 2011 | Nintendo Wii Console
An error occured during the start operation. error 8001002B. Won't load games. But will play DVDs
This error code means disk unreadable, clean up the disk, try also to avoid scratching the disk and to touch the disk with your fingers.
Hold the eject button for a few seconds till you hear a loud sound, this
does clean the blu-ray drive.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Constant disk read issues
It sounds like your laser is going bad. This is a common issue for the PS3. The tell-tale sign is it starts reading less and less and having more errors.
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
Error code can't read game disc, everything else works.
your disk reading lens is dirty or bad. you may try cleaning it with a q tip and rubbing alcohol. If it still does not work it will need to be serviced
Mar 10, 2009 | Namco...
Console problem
I'm having the same issue. Doesn't matter what game disk is in, after a little while of playing, the screen goes black with the message that disk can not be read. Eject disk and power off, then power back on and re insert disk. No error code is given. I just bought this console yesterday and this error has happened probably 10 times already. Wanted to get online and see if this was a common wii problem or I just possible got a bad one.
Jul 31, 2008 | Nintendo Wii Console
During Game Play Of Grand Theft Auto Vice City
The Disk May Be Internally Damaged Or Externally Damaged, I Would Advise To Get A Disk Cleaning Machine. Or Inside The Console The Laser That Reads The Disk May Be Broken Best To Send It To A Game Shop Or Your Nearest Retailer.
Jun 29, 2008 | Sony PlayStation 2 (PS2) Console
Ps3 disk reading error
Can you be any more specific? is this a problem with one disk, one type of disk or all disks? What is the exact error you are getting? Are you trying to play a game, play a film, play an audio CD or are you using your PS3 as a Linux computer and trying to open a data disk? have you tried more than one disk? Without specifics there's just no way to guess what the problem is.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Playstation won't read game disks
What you probably have is a disc read error, if you don't want to get a new system first you can always open it and repair yourself but that voids the warranty but is voided after the 30th day, I have tried it a few times in the past and it works but is time consuming and if your not careful you can break it beyond use. But if you're brave read this article.
http://arstechnica.com/articles/paedia/hardware/ps2.ars
Dec 11, 2007 | Sony PlayStation 2 (PS2) Console
Disk read errors
I have the same model, What could be going wrong is your Power Callibration for the Laser might be off (Look on Youtube for Repairs on how to fix this) The site is : www.youtube.com Search "PS2 Repairs" :)
Jul 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 will not play DVD
Make sure the disk is compatible and not damaged.Try playing another disk and see what happens if you still do not get anything you may want to consider a xbox or 360 with remote control for dvds. Also check to see if ps2 has a remote for playing dvd disc. never worry!!
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Nintendo GameCube Console Logo
144 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
