Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
Zojirushi bread maker, BBCC-15, Baking Pan,Paddle drive seal
Froze up, distroying seal.1, How to remove / replace seal?( seems to be pressed in?) Drifted shaft out. Where to get replacement seal? Better yet would you know where to get new / used baking pan?
  • katskat Feb 02, 2009
    The paddle drive on my pan has frozen. I called the nearest official Zojirushi repair service who told me that the replacement pans are no longer available. Everything else works just fine. Sure would like a solution to this problem. Thank you.
  • Anonymous Aug 13, 2015
    You can remove the circlip from the bottom of the pan, soak the pan in soapy, hot water for a few hours, and it should loosen. If the paddle shafts are working their way out, don't bother replacing the pan. Just pre-mix the water, salt and sugar in one container, the rest of the dry in another. With the pan+paddles in the machine, add some of the dry, start mixing cycle, then add the liquid, more dry, liquid, etc,, until everything is mixed to dough. No need to worry about and leakage between the paddle shafts and the cylinder that they spin in, the dough mixture has hardly any viscosity, so can't possibly leak through. I was going to replace my entire Zojirsuhi machine, but, using the above method, I'm pretty sure it will go for another year at least.
Where can I get replacement parts for the BBCC-15? My keeper clip underneath the baking pan came off and is lost. It holds the wing clip that drives the kneeding blade in the pan.
Posted on Dec 10, 2008
One of the paddles froze after baking a bread. I was able to break it free but it is still stiff
Sounds like the sealed bearing that the paddle shaft turns on is starting to fail. Fill the pan 1/2 way with warm water and soak for a few times to see it this helps. If not you should start looking for a new bread pan. Sorry Hank
Sep 12, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Rotating shaft will not rotate - during the kneading process nothing happens
1) Make sure bread pan is inserted in the machine correctly. 2) Take pan out of the machine and make sure the paddle spins freely on the shaft. ( If not, sealed bearing is frozen and pan needs to be replaced. 3) Keep pan out of machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not the belt may have come off , snapped or there is something wrong with the motor or curcit board in the machine . Hank
Aug 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
I have a Zojirushi bbcc-s15, and it started to leak from the bottom pan. The felt washer on the bottom has fallen off. Where can I find or how can I replace the outer and inner parts?
All those parts are part of the sealed bearing that is stamped into the bottom of the pan. Unfortunately they can't be replaced and you will need a new bread pan. Sorry Hank
Mar 10, 2010 | Zojirushi BB-HAC10 Bread Maker
Replacement part for my Zojirushi BBCC-X20 Bread Machine
That sub component consists of a sealed bearing and seals that are spot welded onto the bottom of the pan. Unfortunately you can not purchase this assembly separately. Sorry Hank
Feb 12, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Bread machine
The Manual can be Downloaded Here This is the Manual for the M15, however the site says that the N15 is shipped with the M15 Manual.
Jan 03, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Hi terryhassler,
If you're looking for OEM parts, I'd go to
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If these don't pan-out (no pun intended, I think), the next place I'd start hunting is eBay.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 10, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
I need a new baking pan and kneading paddle for a Zojirushi Home Bakery Model BBCCQ-S15.
abtecparts.com has almost every kneading paddle and accessory you can imagine.
Apr 19, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Hitachi bread maker
I had the same problem after storing my machine for several years, BUT, I lucked out...I just added a little warm water to my pan and then turned the machine on and let the paddle turn a few rotations and walla!!....it freed itself and is now making great loaves once again!
Jan 26, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
790 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
