Question about Maytag Neptune MAH5500B Front Load Washer
Washer will start, no water comes in, then shuts off.
I have a Maytag MAH4000AWQ. I noticed that when I start the Washer by pressing the Push to Start button, it sounds like it's trying to start itself but no water will come in. Then after about 25 seconds it shuts off. Any suggestions anyone???
  • sdmc73
    sdmc73 May 11, 2010
    will the unit spin if you set it on spin and dose the door lock
  • 79 Answers
It could be the motor control board loacted near the floor on the right side. See for disassembly photos. Inspect board for a blown fuse or burnt components.
Do you know if the door latch wax motor has been changed yet? See for a video that explains the faulty door latch issue.
Posted on May 23, 2009
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
The water won't stop therefore its pill out of machine. Have to manually turn the machine off, shut off water. Is there a sensor, leveler that may be defective? The machine model is MAH4000AWQ. Your help...
Check water level switch sensor. a small tube will be connected to this switch from the washer drum. This tube carries water inside the sensor assembley and senses!
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Where is the water valve? the water keeps running when it suppose to stop. I noticed on the spin cycle when it finished the water was running when i opened the top to get the clothes out.
The first thing I say is unplug the washer. If the water is stillcoming in,(which it will on a stuck valve) shut off the waterfaucets. If that is not possible shut the water meter off. If you canstop the washer with the timer then I would say instead of a bad valveyou have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpgAs you can see the rubber tube from the bottom of the tub allowsair pressure to push against the switch till it shuts down the valveand starts the wash cycle. Remedy this problem: Simply remove the tubefrom the switch and blow it out. Use them lungs!. Get that sand andtrash out of the sump. Reconnect the hose tightly and pump out anystanding water. Then restart the machine. If you have a good tightconnection the machine should start working like normal. No partsneeded!
Oct 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leaking from lower connection of tub coming from pressure switch.
Hi, If you remove the screws on each side of the door opening, the front panel will come free. You might be able to lok in and see the preasure hose. Id the hose leaking or the cup it attaches to?
I hope this helps. Please let me know if I can assist you further. Thanks
May 23, 2009 | Maytag Neptune Washer
Maytag quiet series 200 won't start
Does it help to push it more tightly shut...or fiddle with the latch.
Mine is not running consistently unless we push the door shut tightly. Others here also report problem with the safety latch causing this washer to quit. May have to replace the part.
Oct 18, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
