Question about Neso Technology Pixo A700 17 in. Flat Panel LCD Monitor
Pixo at700s monitor
Monitor has just went black. The on light does not ven light .. what could be the problem?
My screen just went black
Hello, if the Toshiba monitor went black: 1)if there is power from the monitor, check power cable and data cable 2)make sure that its properly connected to the computer 3)make sure computer is on and there is an activity from the computer 4)if the is sound from the computer try a known good monitor if that will work 5) try this Toshiba monitor to a working computer 6)try checking the monitor maybe the back light is busted get a flash light point it directly to the screen it self check if you can find something 7)if all is done bring monitor to a repair station if in warranty manufacturer Thank you for using Fixya
Mar 06, 2011 | Toshiba Computers & Internet
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
When i install vista and upgrade video driver moniter unable to display resolution pixo a700 moniter
press f8 and keep pressing untill menu appears tjen highlight on enable vga mode and press enter your problem will be solved if you want to see high resolution then insert an AGP card into an AGP slot then you can see high resolution use 8X AGP card for better result
Apr 29, 2010 | Neso Technology Pixo A700 17 in. Flat...
None of the speakers work
did you connect the sound cable to the line out of the audio card?
Feb 06, 2010 | Trg Pixo Corion C700 (Black) Monitor
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
My Samsung 213T monitor went black. Power light
I will not be surprised that it will be bad capacitors, that is the first place to check, see some samples here:
Jan 04, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
Unable to get power to Pixo AT500S monitor
if youre handy with tools , check a COLD SOLDER where a TRANSFORMER is re solder any suspicious solder or burnt .
hope this helps AJ
May 03, 2009 | Trg Pixo Corion C700 (Black) Monitor
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Neso Technology Pixo A700 17 in. Flat Panel LCD Monitor Logo
116 people viewed this question
Top Neso Technology Computers & Internet Experts
David Payne
David Payne
Are you a Neso Technology Computer and Internet Expert? Answer questions, earn points and help others
