Question about HP Photosmart C3180 All-In-One InkJet Printer
Doesn't print My printer doesn't print.  The cartridge is full but when the paper comes out, it is blank  Help please
  • Anonymous Nov 30, 2008
    Mine won't even print color! I have cleaned the cartridges, but nothing! I've never gotten to use this printer--it came like this straight from the store!
    TOTAL ****!
  • 38 Answers
The head is blocked and needs either cleaning or replacing - usually cheaper to replace the printer
Posted on Nov 22, 2008
Why is paper blank
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 3600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 12, 2012 | Lexmark X3650 Printer
My lexmark is connected to my pc, my ink is more or less full it is making all the right noises for printing but the paper comes out blank...........please help its a lexmark 12
Try to re-seat your ink cartridges by removing it from the printer. Then unplug and replug your printer into the power source to reset. When the printer turns on, reinsert your cartridges and make sure they're properly secured. Let it print an alignment page. Or try to print again. If still nothing is printed, your cartridge nozzles may need some cleaning. This article in the Lexmark website will give you steps on how clean the cartridge nozzles: How to Maintain the Print Cartridges on the Lexmark All-In-One Printers
Apr 18, 2011 | Lexmark X2670 All-In-One Printer
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Paper blank
You should have to do a "paper alignment" or follow the "new cartridge" prompts.
Mar 08, 2010 | Dell Inkjet 720 Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Blank paper
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Mar 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Printer wont print
On some of these inkjets, if the color cartridge is out or dried up from little use, they will not print using just the black cartridge.
Mar 30, 2007 | Epson Stylus Color 740 InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
135 people viewed this question
Ben Johnson
