HP LaserJet 1300 Printer
Problem for HP LaserJet 1300 Printer
1300 laserjet with smudges
By gramsharon on Dec 26, 2006
My printer is have a smudge down the center right of the page and it has some ghosting. I have cleaned and cleaned and it still is doing it. what do I do?
Comments:
Dec 26, 2006
- I did, and it is still the same thing. I am afraid it is the fuser, but I am hoping not, I don't want to replace that, I will just get another printer. The cartridges I am using are HP brand, and the other one didn't have very much wear from it either.
I just don't think it is worth the $100 plus to fix this, if that is the problem.
Same Problem
Mar 07, 2008
-   I have an HP LJ 1200 with the same problem. There is a smudge line of excess toner that occurs down the center of the page. If I pull out the cartridge and open it I can see the extra toner inside and I wipe it off with a lint free rag. I also wipe the extra toner off the roller. This is usually good for one or two pages and then I have to pull it out and wipe again. If I print a several page document the smudge line progresses from about 1" to a big ugly 3-4" smudge.
This happened with the last cartridge I had (a genuine HP) and the current one I have (a knock-off). Both of the previous cartridges worked cleaning at first and then started this problem about half way through. Before these two I was able to print all the way to cartridge empty - no problems.
I have most docs set to Economode and Faster Printing.
-   Jfer
Solution #1
posted on Dec 26, 2006
Somewhat Helpful)
tomj23
Rank: Guru  HP Computers & Networking  Expert
Rating: 87%, 1838 votes
Have you tried replacing the toner cartridge with a new HP one? Most of the time problems like you describe on this variety of printer (for me anyway) wind up being a poorly refilled or damaged cartridge.
Comments:
Mar 19, 2007
- Over the years I have generally found that refilling toner cartridges is more of an art than an exact science. Depending on who you buy from the quality standards can vary greatly no matter how ?big? the company supposedly is. I don?t buy refills for my offices any more since I was spending too much time monitoring print quality. Kind of a side benefit is now that they are paying a little bit more people are more aware of what they print now.
Having said that ghosting or double images are typically not something you would see from a refilled cartridge unless they are taking shortcuts and note replacing the parts like they should. The first thing I would do it purchase or better yet, borrow an HP cartridge and see if your problems go away. If not post anther question and I?ll pickup when I get home in a few hours.
Was this helpful?
Yes
No
Solution #2
posted on Jan 23, 2008
Not Rated)
SmartGuides
Rank: Apprentice
Rating: 0%, 0 votes
I remember the days of my youth when I used a barrel printer with the nastiest process you can imagine, making copies at the YMCA in Baytown TX. I now have a HP LaserJet 3600n that I had the same center smudge issues,.. when I print post cards and flyers for my real estate business in Tarrant County. SOLUTION: (doesn't COMPLETELY remove the smudge,...but 95% better!!) I drove to Wally World and purchased a bottle of 92% alcohol,...yes in the drug & deoderant area. Cost,..$1. Very carefully pull the front door back and you'll be able to see the build-up on the black film. Small amount of alcohol on a pure cotton ball with gentle force make small strokes to clean and two dry cotton balls to wipe the film from one edge across to the other. Make sure you look at the film from an angle to see the reflection of the areas that may need an additional touch up. print one page,...repeat the process to get the back half of the film. If you need help in real estate,...tarrantcntyhomes dot c0m.
Was this helpful?
Yes
No
Solution #3
posted on Jan 05, 2008
Not Rated)
MFAG
Rank: Apprentice
Rating: 0%, 0 votes
DEAR
THE FUSER FILM IN HP 1300 GO TO RIEGHT SID SO IT WILL DAMEGE WHAT CAN I DO
Was this helpful?
Yes
No
Solution #4
posted on Oct 10, 2007
Not Rated)
Cops
Rank: Master
Rating: 79%, 95 votes
unfortunatly it is the fuser unit that is causing this problem. you will only ever get ghosting from a fuser though if you feel up to it you can save some money by just replacing the fuser sleve instead of the whole unit.
Hope this helps
Cops
Pete@wedotoners.com
Was this helpful?
Yes
No
Solution #5
posted on Aug 10, 2007
Not Rated)
Thecus
Rank: Master
Rating: 79%, 57 votes
If you replaced the cartridge and does the same thing then it is the fuser. The fixing assembly does not need to be entirely replaced you can first clean the black teflon film with laquer thinner or just order just the fixing film, which is the heater element. HP parts are much more expensive than Canon parts. FYI the HP printers are made by Canon.
Was this helpful?
Yes
No
Solution #6
posted on May 07, 2007
Not Rated)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
it's a toner problem, I am on my 5th refill toner.
Solution #7
posted on May 06, 2007
Not Rated)
bbazz
Rank: Guide
Rating: 88%, 12 votes
sorry to say but it does sound like the fuser. you may not necesarily have to replace it. it could just need a good cleaning on the fuser rollers. it is best to let a repair man do it. if you want to try make sure fuser is cool. be very careful not to scratch the coating and do not touch roller surface with your fingers. Sorry I can't think of a home cleaner to use, you could try isopropyl alchohol. but I am sure you will find an image baked onto the upper roller will will need to be cleaned off.
Was this helpful?
Yes
No
Popular Solutions for HP LaserJet 1300 Printer
Questions and Unsolved Problems for HP LaserJet 1300 Printer
Do you recommend HP LaserJet 1300 Printer?
Answer
Answer
How to clean printer head so that paper does not get ink lines running through it. Every printed... (More)
Answer
When giving my HP 1300 laserjet a printingjob for a example 20 pages only a few prints take place.... (More)
Answer
yellow light even after checking all connections and rebooting computer - yellow light does not... (More)
Answer
paper is coming out creased as if there is something stuck but there is nothing visible wher should... (More)
Answer
My father bought me a new printer. The printer is a HP Deskjet D1460 and my laptop cannot recognize... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Printer Ink & Toner
HP LaserJet 1300 Ink
Save up to 76% on
Limited Time Offer:
Additional 10% Off All Products.*
When you use coupon [WINTERTEN] at checkout
Free Shipping on all U.S. Orders over $50
*exp 03.31.2010 excluding OEM ink
Top Printer Experts
Top Printer Repairmen
in , NY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
