Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Broken MAYTAG glass cooktop
Question: My glass top has a crack about a foot long going across one of the burners. Is is safe to use the burners that are not cracked ? If moisture gets into the cracked section, will this be dangerous? I, too, am not impressed with Maytag..anyone find a cheap place to buy tops?
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: I have a Schott Ceran cook top that is marred with
Use oven cleaner. Spray it and let it sit on a couple of hours. Scrape with a razor blade. It worked for me after trying everything recommened by the manufacture.
Posted on Mar 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: An area near, but not through, a small burner is
It is simply a cosmetic issue.
The heating elements are not embedded in the glass top - they are underneath.
Using the burners will be fine.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
milten1
  • 1304 Answers
SOURCE: moisture is accumulating on top of the freezer due
its safe but will be a pain
if you have a small crack in the liner
you can buy white tin tape and get a good seal again
but if you willing to deal with it
and wipe it down alot
you will be fine
Posted on Oct 06, 2009
Testimonial: "Cheers mate, thanks for your rapid and expert advise."
  • 127 Answers
SOURCE: Frigidaire PLES389DCC MODEL Electrolux
318223626 - MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
Posted on Oct 27, 2009
I own a Maytag Glass top electric range stove. Model # PER5710BAC. The glass stove top cracked straight down the middle, and one of the bigger burners doesn't heat up anymore. Is there any way to repair...
You could try purchasing replacement parts from a local appliance parts supplier and you might be able to get advice on making the repair. The supplier can advise you of the cost, allowing you to decide whether it is economically worthwhile to repair the range. You also have to consider your degree of confidence in your ability to do the necessary work
Sep 29, 2013 | Magic Chef 30 in. 8241RT Gas Cooktop
I understand all the troubleshooting / repairs for this cooktop (Maytag / Whirlpool CSG7000), but I need to know...How do I separate the glass top from the steel pan without breaking it? Can't get at the...
You will have to use a putty knife to separate the top from the burner box.
After you do your repair you will also need 107 inches of burner box tape to re-seal the top.
Jul 26, 2010 | Maytag 30 in. CSG7000 Gas Cooktop
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
I NEED TO REPLACE BROKEN GLASS TOP OF MAYTAG MODEL
ITS A LITTLE TRICKY, WHEN YOU GET YOUR NEW ONE LAY DOWN A OLD BLANKET PUT YOUR NEW ONE UPSIDEDOWN ON IT DISCONECT POWER THEN REMOVE YOUR OLD ONE .OPEN THE OVEN DOOR THERE IS 2 OR 3 SCREWS ON THE TOP OPENING HOLDING IT DOWN REMOVE THEM AND SLOWLY LIFT TOP UP AND SLOWLY PULL FORWARD. YOU WILL SEE A CONNECTOR TO DISCONECT ALL THE WIRES THEN LAY COOKTOP UPSIDEDOWN NEXT TO THE NEW ONE. SLOLY REMOVE SCREWS THAT HOLD BURNERS ON BRAKETS. I MARK THE HOLES ON THE BURNERS WITH A SHARPY
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Maytag MER5775Q Electric Kitchen Range
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
Apr 12, 2009 | Whirlpool Accubake RF362LXTT Electric...
I have recently cracked the glass stove top, if I continue to use it will I sustain more damage and how much will it cost to replace it? We have a Bosch 30x24 glass smooth top with four burners electric....
hi gud day,much better to replae the new one compare to buy the glass top only coz the price of the glass is expensive or little diif for the new one.or if the broken glass is not appected to other burner its ok to use the other burner untill to u want to use.tnx
Feb 01, 2009 | Cooktops
Cracked cooktop on Kitchenaid built in cooktop
oh im sorry about that.yes you can purchase a new one.i would shop one line because more competition and then would get a better price you will need model and ser# .just check them out before giving your money.ive sold some last year thru sears as a tech and they were about 400$.you can find a glass top range on sale for about that much,but wont be an kitchen Aid
Jan 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Stovetop stays hot when burners are not on
Is it a glass top. If it is, glass will absorb the heat. It will cool off after some time. That is normal.
Dec 18, 2008 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
73 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
