Question about Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine
2 of my units are stuck on CONFERENCE CALL.
When I turn the phone on it reads CONF CALL.I can hear fine but I can't be heard.2 of my 3 units are stuck on that mode and I don't know how to get out of it.
  • Anonymous Dec 07, 2008
    Phones are stuck on conference call mode.
2010 F150 Lariat. Dual climate control works only on passenger side. Rear temperature controls work fine. Driver side or left vents only blow hot air. Regardless if AC is turned on or temperature...
If the driver's blend door actuator has failed completely, or the wiring to it is damaged, you will not hear any clicking. Check for appropriate voltage at the blend door actuator, and determine from there if it's the actuator or the control unit.
Dec 20, 2016 | 2010 Ford F-150
Unit powers up, cd and radio seem to be operating properly, but no sound is heard, unit worked fine a few days before, all wires are conected, everything seems unchanged you said...the unit powers you don't have a "dead set".I don't know if the speaker can be disconnected from the unit.As a rule of is very rare that both channels (left and right )fail at the same is usually one channel while the other speaker still operates.This is what I want you to do...In a quiet room..get really close to the unit...Switch it on and listen for any sound from the speakers...get really should hear a slight hum from the woofers and a high frequency "hiss" from the tweeters....If no sound is heard..switch the unit off..You should hear a "plip" sound...If not...switch it on should hear a slight "bump" sound from the woofers...If you hear no sound from the speakers at all..there is a problem with the output stages of the amplifier section.If you do hear sounds fron the speakers,,Turn up the volume and watch for an increase visually on the display (such as ascending numbers).If there is no indication of a volume increase...The "mute" may be stuck on..Try switching it off and on...please let me know what happens after you do all the tests....Looking to hear from you......PEACE!!!
Jul 11, 2011 | JVC HX-Z3 CD Shelf System
Would you please help me with how to set up a conference call?
Make call or when you have answered a call.
On the screen will appear CONF, PAGE, and MUTE
Press left hand soft key that is under CONF
Make next call by dialling 9 plus no. or the extension no.
Once you have the person you wish to speak to connected press CONF twice until you are all connected together.
You can have up to 5 people in a conference, you just repeat the process.
To leave the conference but leave the other parties to carry on (unsupported conference) Press CONF followed by your own extension no. This has to be the extension which started the conference.
Hope that this helps, I have also uploaded a video off showing how to do conferencing there are loads of others on that site.
Apr 25, 2011 | Samsung Prostar DCS Phone
Who do you make a conference call
While you are speaking to a party, all you have to do to add people is
1) Press the Conf button.
2) Dial the number for the new party.
3) Talk to the new party.
4) Press the Conf button again. You will hear a tone and then all parties will be able to hear all other parties.
To leave a conference call you just press the Conf button, listen for the tone, and hang up.
Mar 17, 2011 | Panasonic KX-T7630 Corded Phone
How do I make a conference call on a Panasonic KX-T7436 Digital super hybrid system
while talking to someone:
1) press "CONF"
2) dial the extension number (or 9+the phone number) you want to conference in
3) wait for the person to answer
4) press "CONF" again
Jan 03, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
How do I make a conference call?
Hi this is a great feature on the Samsung Prostar, I actually find the screen prompts easier to follow than the pre-programmed button. Whilst on a call the display will read ' CONF PAGE MUTE' press the 1st small button under CONF. then dial the number, externally or internally, that you want to bring into the conference. then press CONF again twice, this links the members together, you will see that the CONF is now under the 3rd softkey. up to 5 people can be on a call at one time if you have enough channels (lines) available. I have uploaded a video which will help explain this better or visit , I hope that this is of some help.
Sep 14, 2010 | Samsung Prostar 816 Phone
I would like to know how to make a conference call
While your connected to the first party, press the Conf key.
press an idle line (or intercom).
call your next party.
press the Conf key again.
you can repeat steps 1-4 to add up to a total of 2 outside and 2 inside connections.
to remove the last added outside party from the conference press feature 06
Sep 13, 2010 | Lucent PARTNER18 Corded Phone
How do i do a call conference from KX - t7730
hi pgoyal
During a two-party conversation,
1. Press CONF button. (The current party is placed on hold.)
2. Enter the phone number of the third party.
3. Talk to the third party.
4. Press CONF button again.
A three-party conference is now established.
Jul 28, 2009 | Panasonic KX-T7730 Corded Phone
My Samsung Instinct is stuck in headset mode
DONT DO THE RESTART/ERASE CODE!!!!!!!!!!! its a hardware problem, not software or virus. your phone is probabluy stuck in headset mode, where you can hear the ringtone for incoming calls and alarms but not calls (without headphones). you three real options are to (1) stick a boby pin or stylus into the jack until it leaves headset mode (2) more invasively, find a really small screw driver and open the phone(screws are under the battery cover, in the corners) and poke in the earphone jack or (3) get a new phone. thats all i can tell you.
May 05, 2009 | Samsung Instinct Cell Phone
Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine Logo
168 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
