Question about Zenith VRE4222 VHS VCR
Can't access onscreen menu
I was given a Zenith VRE4222, but without a remote. I purchased an RCA universal remote and was able to program it. The VCR turns off and on, changes channels, records, plays, rewinds and fast forwards, , but when I press the menu key nothing happens, so I cannot set the clock or program it to record. I thought maybe there was something wrong with the remote, but it works fine with my TV, including accessing the onscreen menu. So I'm stumped. Should I return the remote I bought and try another one?
Kimi
  • 277 Answers
SOURCE: The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Posted on Nov 22, 2005
techman
  • 3130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
ok sorry man gotta step in Its not the pinch roller as you claimed that picks up the slack on the tape its the pinch roller that would cause wow and flutter in audio on a tape on slower speeds what picks up tape slack is the takeup reel. Theres many reasons why the takeup reel dosent pick up the tape and there fore the unit "eats the tape" it could be a gear assy or even on older units could simply be the rubber drive wheel. Or a belt problem and I know these JVC s really well and its a combo the drive belt as well as the pickup gear assy.
Posted on Apr 04, 2006
  • 979 Answers
SOURCE: I cannot get program recording with timer set.
Problem seems to be related to the "write protect" tab on the tape not being sensed. Is the tab removed? That would explain things there...accordianman
Posted on Jan 21, 2008
  • 579 Answers
SOURCE: Sony VCR rewind and counter problem
The belts are slipping. Every 5 years is about right for replacing them all.
Posted on Jan 24, 2008
sharcnet
  • 2130 Answers
SOURCE: Sony VCR
I'm not sure how old your unit is but over time, the rubber parts in a VCR become cracked, glazed and begin to slip.
There is a rubber wheel about the diameter of a nickel that is called the pincher wheel and does exactly what its called.
It pinches or compresses the tape against a shiny metal spindle called a capstan. The capstan spindle is connected to a motor. The pincher wheel rests against the turning capstan with the tape in between the wheel and capstan.
The pincher wheel can become glazed and coated with a brown oxide that has worn off of the tape. This causes the tape to slip and it can spool out into the VCR.
There is another wheel called an idler tire. It lays flat and pivots between the sending reel and pickup reel. Its used during play, fast forward & rewind. This wheel too can become glazed and worn causing slipping. If your unit won't play, fast forward or rewind, most likely the idler tire is the culprit.
There are also belts that can also become glazed and worn. These belts are used along with motors in the tape load/eject mechanism and capstan drive. If the belts slip, the tape may not load or eject properly and the capstan might not be turning properly.
When I owned my repair shop, one solution was we to remove the belts and/or tires and apply a re-grip solution on the rubber with a cotton swab, while roughly rubbing the the entire rubber surface back & forth with the swab. The re-grip solution actually eats away the top surface of the rubber leaving the rubber surface course and causing it to grip better.
Another solution was to just replace all of the rubber tires and belts. These parts including the re-grip solution may be ordered through www.mcmelectronics.com
Please let me know if I may be of further assistance to you.
- Jim
Posted on Feb 26, 2008
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
Zenith TVBR1322 9 In. Combo universal code
Universal remotes will be missing key functions in these units.
Zenith (and for that matter most brands) do not make these units--about 4 companies make most of them.
Your best bet is to try to locate an original remote--Zenith(LG) or Google the model number "original remote" or even search EBAY.
Mar 21, 2012 | Zenith TVBR0922Z 9 in. Combo
I have a Zenith VCR Model VRA423 S/N S87031128. The Remote works except for the number 3. I have purchased a universal remote, but I need the three Digit code to program the universal to function.
hi,
u didn't mentioned, to company which the universal remote belongs. without that, how can anybody give u the code. feel free for further assistance.
ok
Dec 17, 2010 | Zenith Televison & Video
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Cant get my universal remote to work my Zenith model TVBR1922
ha i can help a little ,i also have a rca universal and same tv,vcr combo,the codes in the list rca provides
do not work ,but if you go through the code search procedure componet vcr,until the set turns off
hit enter,this will allow for power on off funtions and ch up down or number keys,also vcr functions,
but no vol, control or menu nevigation,hope this helps a little
Jan 08, 2009 | Zenith TVBR1922 19 in. Combo
Cannot program new phillips remote to rca tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Dec 02, 2008 | RCA DIRECTV Satellite Remote Control
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Feb 27, 2008 | Televison & Video
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
1995 RCA TV/VCR REMOTE CONTROL CODES
I need the codes to this tv so i can program a remote please reply
Nov 20, 2007 | Televison & Video
Zenith VRE4222 VHS VCR Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
