Question about Olevia LT27HVX 27 in. LCD Television
One verticle line appeared
I have had my tv for two years. Yesterday a vertical red line appeared about 1/4 in from the left hand viewing side. It went away for about two hours and has once again appeared.
Can this be fixed? Is it worth it or do I just hope it goes away?
Same thing happpened to us with a Vizio 26" TV. Its a defective panel,and cannont be fixed, we were told. Vizio replaced the TV under warranty.
Posted on Nov 07, 2010
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 30, 2015 | Sony Televison & Video
Thin vertical line on plasma, 4 inches from left hand side
According to what i could find, there is no way to actually SOLVE the problem, this is what i did find; The plasma display panel is lighting the phosphors by the discharge of internal radiation. Depending on the screen contents, in rare cases this may cause vertical stripes to appear because of failure to light. Please note that this is not a malfunction.
Aug 10, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Verticle red line appeared on screen.
Have you checked what happens when other forms of SOURCES are used. For example, when you switch away frrom HDMI or Tuner, etc. Does this still appear? If not then it could be with a cabling issue or possibly a cab;le/SAT, DVD, etc. issue. But if it persists, then it's totalled, unless it doesn't bother you.lol..... Good Luck!
Nov 23, 2008 | Olevia LT27HVX 27 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Olevia LT27HVX 27 in. LCD Television Logo
157 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
