Question about Dell E171FP 17" Flat Panel LCD Monitor
White horizontal bar on the bottom of Dell E171FP monitor.
We recently turned on our computer and there is a white horizontal bar on the bottom of the monitor display. There seems to be no way to get rid of this white bar with colored vertical lines thru it. Can this be fixed? Thank you.
Al
  • 1 more comment
  • albdoc00
    albdoc00 Nov 22, 2008
    Here's a picture of what it looks like. Thanks again.
    Al
  • uhsthmom Apr 02, 2009
    same problem! what is it & how to repair ... or should I just dump this thing & buy an apple
  • Anonymous Apr 14, 2009
    I have the same problem with a Samsung 2233SW only the bar is on the right hand side.
  • 1153 Answers
SOURCE: dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Posted on Sep 14, 2007
  • 238 Answers
SOURCE: Dell e171fp + turn off after a second
check for power management settings in the LCD menu, or does it switch off while u r in the menu.. what does the power LED indicate after switching off, also sometimes display cards do act funny.. check it out an d let me know
Posted on Dec 15, 2007
  • 55 Answers
SOURCE: my dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Posted on Mar 16, 2009
  • 73 Answers
SOURCE: Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Posted on Jul 24, 2009
  • 85 Answers
SOURCE: My Dell P2310H monitor has
This occurs when you have lines of pixels go out or your video card has gone bad on your computer. You should hook it up to another computer to confirm which is causing the issue and repair/replace the problem device.
Posted on Apr 01, 2011
Lock icon and menu keeps appearing
Anonymous,
To unlock the monitor controls and get rid of the Lock, press and hold the monitor Menu button for 20 seconds. You can also try this.http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L.
Dell Social Media and Communities
Feb 28, 2015 | Dell E171FP
Why is my Dell Monitor Blank
If you have another computer, try and see if you can hook it up to that and test it. If it still doesn't work it may be dead.
Sep 02, 2014 | Dell E171FP 17" Flat Panel LCD Monitor
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
White horizontal bar at the bottom of the screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty usually its for 3 years
Apr 10, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
DISGUSTING WITH THIS THING AND THE MENU
it must have gotten to your computer through internet downloads, its malicious, so get a good anti virus and scan your computer, thanks
Jul 16, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Powersave
If it's going into powersave mode, it usually means it's not getting a signal from the video card. Try plugging this monitor into another machine or laptop and you should be able to tell if that's the issue.
May 26, 2008 | Dell E171FP 17" Flat Panel LCD Monitor
How to replace a power adapter on a Dell E171FP LCD
this is a monitor you shuld not open this as it has very high power running thru it. get dell onto it
Apr 24, 2008 | Dell E171FP 17" Flat Panel LCD Monitor
hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dec 15, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
My Dell E171FP Is Dead!!
Order new capacitors and replace. I had the same problem with mine and with $4 and a soldering iron I got mine back up and running.
Check www.badcaps.net for monitor repairs...
Nov 07, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Dell E171FP 17" Flat Panel LCD Monitor Logo
544 people viewed this question
Alun Cox
