Question about CorningWare SC60 Slow Cooker
How do I get both 8 hours time and high setting on this crockpot?
Bought the Sc60 Corningware Programmable crockpot off the shelf without book... maybe not smart. I can turn it on, get it to 8 hours, but cannot with only an on/off button and hours button, get it both on *high* and 8 hours at the same time. with the off position, I can easily get the hours, but I can't move the light from low to high. If I push the off button and then move it to high with the hours button, then I lose the hours. With it ON, I can't set the hours..... HELP!
Housemouse
  • 1 more comment
  • angelbunny Dec 30, 2008
    i can get the hours set but only on high or warm, not anything on low
  • tsogilvie Mar 04, 2009
    I do not have the instruction booklet and I don't know how to program the buttons.
  • stevielynne Mar 04, 2009
    You actually have to set it for a smaller # of hours to get it to start out on high. If you set it for higher than 5 or 6 hours it will start on low and then later progress to high, but if you want to start out cooking on high you have to set it for 4 or 5 hours on high, then add several hours later on. It's a pain. I lost my manual, but I did figure out that the lower # of hours let you start cooking on high.
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Posted on Nov 23, 2008
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
Broke my glass lid want to replace it . It is the sc6 date code 150107
I need a glass replacement lid for a Corningware crockpot model
SCO-150 It is 120 vac 60 Hz 34OW. Thank you, Grace Brown.
Mar 27, 2011 | CorningWare SC60 Slow Cooker
I'm looking for the manual for the Corningware SC-60 slow cooker. I need to know how to set the time and temperature. Thanks!
Couldn't find a manual but here's how you can set the time and temperature: http://www.ehow.com/how_6496690_set-timer-corningware-slow-cooker.html Hope that helps.
Jul 27, 2010 | CorningWare SC60 Slow Cooker
Is there a timer I can purchase for the SC60?
A timer would probably work for a slow cooker with only a switch for low, medium or high on the front of the cooker, but this slow cooker requires that after you plug it into the wall you have to tell it how you want it to cook, it won't start cooking automatically. In other words, you have to press buttons to make it cook. Hope that's clear, I know sometimes I'm not.
Apr 10, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
Corningware Crock Pot SC 3544
the auto setting cooks on high for the first hour, then adjusts to cook on low for the remaining time. hope that helps :)
Feb 11, 2009 | CorningWare SC60 Slow Cooker
This is ridiculous. I just want the manual for the corningware sc 60 slow cooker so I can print it out. Why all the runaround. This should be simple
1. Turn off and unplug the slow cooker first.
2. Plug it in, but (yes, I know this sounds crazy) DO NOT turn it on.
3. Set your cook time and it will automatically set the temperature based on the cook time.
he The magic number is 7. Anything set for less than 7 hours will be cooked on high. Selecting a time more than 7 hours will result in cooking on low. Once the cook time has expired the cooker will automatically switch itself to warm until you turn it off. Follow these steps and you should be able to enjoy your cooker again! I don't know who was in charge of this type of setup for programming but they should be demoted at least - no wonder there are so many questions online about this one. Sure hope this helps you!
D
D
Nov 29, 2008 | CorningWare SC60 Slow Cooker
Lost Manual
When you plug in the slowcooker do not press the on/off button first. Select time in hours first. If you select 1-6 hours, it will automatically set itself on high, 7-10 hours will set to low.
Sep 30, 2007 | CorningWare SC60 Slow Cooker
CorningWare SC60 Slow Cooker Logo
312 people viewed this question
Top CorningWare Crock Pots & Slow Cookers Experts
charles
Gerry Harvey
Gerry Harvey
raysaw
Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
