Question about BenQ DC E53 Digital Camera
Benq dc e53
My viewfinder gives a good preview but the picture is whited out on both sides about one third of each side.this applies with and without flash.can anyone help> i have had no response from benq so far. maybe they have xmas off work too!!
2 Suggested Answers
  • 2985 Answers
SOURCE: Unuseable benQ Camera
Alas these small items are designated 'Consumable' and are serviced by replacement
In other word it is time to buy another
Posted on Jan 24, 2008
SOURCE: drivers
I need a website were i can download the driver for my Benq DC C500 so i can load my photos up to my laptop.
Posted on Jan 18, 2010
0 characters
1 Points
This card can not be used
Do into the camera's Menu and fornat the memory card.
May 29, 2012 | BenQ DC E53 Digital Camera
My camera benq dc e600 when I take image in sunlight it view and be very dark (black) image this probelm just with sunlight
If you mean the image can't be seen in bright sunlight but you can view it just fine when you bring the camera indoors, this is a common problem with all digital cameras.
Apr 07, 2011 | BenQ DC E53 Digital Camera
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
It says "sd door open"
SD Door open means that the SD card Slot door is not clsed properly. open the slot remove the card & re insert the card & close the door.
May 08, 2010 | BenQ DC E53 Digital Camera
I need a battery for it
Ebay is as good as any for this kind of supply.
Watch out for low battery price but artificially high shipping - you need to keep an eye on the total value of the order (which should be around $8 delivered, with a one year guarantee).
For example:
Apr 28, 2010 | BenQ DC C500 Digital Camera
Picture is white
Don't know your specific camera, but it sounds like you have it set on manual (does it have P, A, S, M settings?) with a long shutter speed. This would let in a lot of light outside, and make all of your pictures blurry.
Change your setting to P (program) or Auto (automatic) and see if that helps.
Mar 18, 2009 | BenQ DC E53 Digital Camera
White preview screen after pic taken
Have u tried switching the view from and eyeview(viewfinder) to LCD while viewing pictures. Sometimes we forget it and panic. Hope it helps. Good Luck.
Nov 20, 2008 | Fuji FinePix S7000 Digital Camera
The shutter remains closed on a DSLR until you take a picture. There is no way to preview an image that does not exist yet.
Being stuck with the tiny viewfinder as earlier cameras had is a good thing. Holding a camera out from your body will give mixed results due to your movements. You will get better results with the traditional method
Jun 08, 2008 | Nikon D40x Digital Camera
Advent camera battery charger
Here's a list of cameras that use the same battery.
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Digital Cameras
Damaged Screen
Check the BenQ tech Support site for service links for Canada or U.S.
May 30, 2007 | BenQ DC E53 Digital Camera
BenQ DC E53 Digital Camera Logo
Top BenQ Digital Cameras Experts
Are you a BenQ Digital Camera Expert? Answer questions, earn points and help others
