Question about Cosco Alpha Omega Elite 5-Point 22-155
How do you install the car seat for rear facing?
I have the manual and it does not help. I am highly frustrated and need help.
  • 1 more comment
  • Anonymous Nov 28, 2008
    3 adults have tried to install this car seat in the rear-facing position, but NO LUCK. It is very unsteady. We will be exchanging this for another!!!
  • Anonymous Nov 29, 2008
    I don't have a manual and you can't find it as costco's website any more.
  • djembe13 Dec 21, 2008
    Very frustrating. The manual sucks!
Hey Just posting this for future reference for other people since I see that you posted over a month ago :) ..
To install the car seat in rear facing I used the latch system. (you can use the latch system if your vehicle has latches..they are tiny metal bars in between the seats)
First of all with this dumb car seat I found out that the latch system was not in the proper place so if you find that yours is not where the diagram shows (in the manual) then you'll have to take off the seat cover and manually put them in their place. Then go ahead and clip onto the latches in the rear facing position. If the car seat is too far forward then inline the seat. If the car seat is still not leaning far enough back to be level with the ground (there should be two level marks on the top/side of the car seat) place a rolled towel (or roll a 2x4 in a rolled towel like i did) then clip onto the latches. Hope this helps someone.
Posted on Dec 26, 2008
2 Suggested Answers
  • 25 Answers
SOURCE: Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Posted on Feb 19, 2009
How to install front facing baby start car seat
Identify the parts. A car seat will likely come with two parts - the base and the actual cradle itself. The base part is what will actually be in the car, while the baby cradle (seat) is removable and portable - the baby cradle can be taken out of the car and easily attaches to most grocery carts (the front part where bigger kids sit) and restaurant high chairs (move the standard restaurant high chair upside down and you will have yourself a cradle holder).
Give it a try. Place the booster flat on the backseat of your car and run the seat belt around it to hold it down - read your instructions and they will have detailed graphs on how the seat belt hurts. Also look at your car manual as they will have special instructions and buckles for car seats
Get confirmation. Move your baby seat cradle on top of the base (remember, it always faces the rear, when your child is old enough you will have to buy a different type of car seat that faces forward towards you). With your hand, sternly move your baby car seat from side to side, if the cradle is easily swaying your car booster is not securely fastened. Remove the cradle and pull the car seat belt as snug as you can and try again
Get double confirmation. Call your local fire department and make an appointment to stop by - they will check and confirm your car seat is installed securely. Remember, this could save your child's life so 10 minutes with your local fire department is only a very small inconvenience!
Oct 20, 2010 | Baby Gear
Mustang rear seat removal?
please rate highly if this is what you need
Section 01-10: Seats and Tracks 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Seat Cushion, Rear Removal and Installation
  1. Release pin from locks by pressing release button under rear seat cushion.
  1. Pull rear safety belt and buckle (60044) through openings in rear seat cushion pad and frame (600A88) and remove rear seat cushion pad and frame .
  1. To install, reverse Removal procedure.
REMOVAL AND INSTALLATION Seat Back, Rear Sedan
Removal
  1. Remove rear seat cushion as outlined.
  1. Remove rear seat bolster. Refer to Section 01-05 .
  1. Remove rear seat bolster mounting bolts. Remove bolster assembly.
  2. Remove four seat back to package tray retaining bolts.
  1. Remove seat back.
May 04, 2009 | 2004 Ford Mustang
Need a car seat manual
Types of car safety seats at a glance
The chart below is a quick guide on where to start your search. However, it’s important to read more about the features and how to use your car safety seat.
Age Type of Seat General Guideline Infants Infant seats and rear-facing convertible seats All infants should always ride rear-facing until they are at least 1 year of age and weigh at least 20 pounds. Toddlers/Preschoolers Convertible seats It is best to ride rear-facing as long as possible. Children 1 year of age and at least 20 pounds can ride forward-facing. School-aged children Booster seats Booster seats are for older children who have outgrown their forward-facing car safety seats. Children should stay in a booster seat until adult belts fit correctly (usually when a child reaches about 4' 9" in height and is between 8 and 12 years of age). Older children Seat belts Children who have outgrown their booster seats should ride in a lap and shoulder belt in the back seat until 13 years of age.
Mar 28, 2009 | Evenflo Ultara I Premier
Alpha Omega Elite
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
LATCH Attached?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Nov 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Eddie bauer rear/front facing manual
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s why a downloadable version of many of our instruction manuals are available right here online. Simply fill out the form below and click Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Apr 16, 2008 | Eddie Bauer 3-In-1 with Latch
Can't Install
You definately should get the rear tether connector to get this car seat in snug. It is the best way and designed to be used rear facing withthe Roundabout. Click the link (or cut and paste into your browser) below to see what I am referring to. When you get it you should connect it to the passenger seat belt track as that is connected to the frame of the car. Richard - www.goores.com http://www.goores.com/goores/product.asp?s_id=0&pf_id=PAOHIDINEIPANKMJ&dept_id=3010
Jun 09, 2007 | Britax Roundabout
Installation of Car Seat base
Try this link it seems very good http://www.aap.org/family/carseatguide.htm
May 13, 2007 | Cosco Travel Systems 01-938 Stroller
Cosco Alpha Omega Elite 5-Point 22-155 Logo
482 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
