Question about Dryers
How to open a kenmore dryer for service, running but no heat, access front or rear of dryer
  • Clifford Gallant Nov 22, 2008
    kenmore elite heavy duty kig size
    mod: 110c64966300
    s/n: mp3501112
  • 324 Answers
Depends on the model.
Posted on Nov 22, 2008
  • i could not find that model listed.
    but i will tell you that if the lint screen is on top then the heater is in the back.
Kenmore 41784082500
To access the heater on this one you must remove the drum. To do so you pop the top. Then you remove the front. Then you release the idler after removing the rear access panel. Lift out the drum and inspect the heater for breaks. My home video:
My Blog with service manuals and more
Sep 03, 2012 | Kenmore Dryers
How do you remove heating element
If the filter is in the top you remove the rear dust cover to get to the element.
If the filter is in the door you must drop the front service panel to access the heating element. I have videos and more HERE
Mar 05, 2012 | Kenmore Dryers
How to remove back to replace element on kenmore 110.63942101
The rear panel does not come off on this model dryer. The heating element is located inside the dryer under the drum on the lower right hand side. You will need to open the toe panel under the door to access the dryer interior. This is accompished by placing a putty knife along the top seam of the toe panel where it meets the dryer front panel. There is a retaining clip about two inches in from each side that you must depress with the putty knife to release the panel. With the retaining clips released, the toe panel will open, allowing access to the dryer interior.
CAUTION: Always ensure you UNPLUG the dryer or secure the power source before servicing anything inside. Dangerous voltage is still present, even with the dryer turned off.
Replacement parts (if required) may be found at the following websites:
If you need a wiring diagram, most of these dryers will have a diagram available inside the operator console for repair technician use.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Feb 03, 2011 | Kenmore 63942 Dryer
No heat and believe it to be the thermal fuse on kenmore dryer 63
Unplug it, remove the back, f73a9b7.jpg1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. heater assembly.
3. 250f limit (if bad no heat, timer won't advance)
4. heater element
5. Fuse(350F), if blown(open) the dryer will NOT run.
(if you do not have a meter remove and inspect this heater coil for breaks).
6. control thermostat
7. heater (warms thermostat to shut it down faster for delicates)
Apr 13, 2010 | Kenmore 63942 Dryer
Where is the heating element in the kenmore dryer
It depends upon the model number.
Most Kenmore dryer elements are accessible after you remove the rear panel of the dryer.
If your dryer does not have a removable rear panel you must open the top lid and remove the front panel.
Jan 16, 2010 | Kenmore Dryers
I'm trying to install a new heating element to my Kenmore dryer 80/90 series. The rear panel does not come loose after I remove all the screws. I need this to come off to install the heating element. Tks
Replace screws at rear exactly as they were. Entrance for this dryer is at the lower front panel.
Unplug unit first. Place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the panel. This will release the lower panel and give you full access to all the main components.
The heater is on the right in the metal can with the cover at the front. On the left side of the can is a thermal fuse that may be open to turn off the heater. There is also a thermostat that may be bad or interconnecting wiring. Remove cover at the front of the can and disconnect wires to element.Element should slide out for replacement. Look for screws retaining it if it doesn't.
Reverse above process for reassembly. Good Luck.
Sep 10, 2009 | Kenmore 63942 Dryer
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Adjust motor/heating elem to put screws back - Kenmore Dryer 417?
pull them away from the wall and see if you have an access panel in the rear of the dryer. If you do remove it and undo the belt so that you can freely sway the drum in either direction. it may re-align the holes for you to replace the screws if not you'll have to open the dryer possibly by prying the top up and undoind the screws that hold the front panel to the cabinet. from there you should be able to move the drum about to get the scres back in but f you do get it opened take the time to clean it out. Make sure you undo door switch wires before removing front panel.
Apr 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 84152
On a kenmore conventional dryer they had for a million years the heating element is on the rear of the machine on the right. Some newer models "princess type" have a lower front panel and a heater that just yanks out for easier servicing.
Jan 20, 2009 | Kenmore 84152 Electric Dryer
Put the back panel back, and hope you havent done permanent damage
the back does not come off roper dryers for service
the front does
the back panel serves solely as a mounting point for important fixtures
there is no reset button
there are thermal fuses, if the thermal fuse, mounted on the exhaust duct or fan housing has failed, it must be replaced, but they are not expensive
look like this de074eb.jpgbcb6b5f.jpg to access the dryer mechanism
unplug dryer
remove lint filter
remove 2 screws under lint filter
with putty knife or other blunt blade, depress spring catches at front corners of top cover
raise front cover
remove 1 screw each side of front panel 1/3 from top
remove door switch wires
remove front panel set aside
test all thermostats heater and thermal fuse with ohmmeter, remove 1 wire test for conduct replace wire, no conduct replace
the local parts store will have the part, labelled whirlpool, ~$14 for thermal fuse, ~$40 if heater
examine rear panel reinstall any thing that is dismounted
while the dryer is open
Clean the lint out of fan, fan housing, ducts
airflow blockage is the 99% cause of thermal fuse blowing, some lint always gets past the lint screen
Oct 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
116 people viewed this question
Top Dryers Experts
