Question about Cosco Alpha Omega Elite 5-Point 22-155
Alpha Omega Elite
I am highly frustrated by the owner's manual. The examples are not clear of how to install the rear facing car seat. Is there a live demostration on the Internet?
  • Anonymous Mar 04, 2009
    We are trying to install this as a rear facing in a 2007 Honda Civic. I'm not sure if it's because the car is smaller or what but the carseat will move more than an inch when moved at the point where the latch goes through the seat. We have tried to use the latch system without the base and it doesn't work any better. We have tried to install it with the seatbelt instead but that just makes the carseat cockeyed (it raises it up on one end).
    We currently are trying to install this in the back center seat. Should we try this directly behind the passenger seat?
  • 25 Answers
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Posted on Feb 19, 2009
Manual car seat model 22456 CAB
hello
i can not install my new alpha omega elite car seat model 22456.CAB please guide how can do it ?
Jan 08, 2012 | Safety 1st Alpha Omega Elite 3in1...
Don't know how to connect for rear facing
Here is a link with instructions to follow to install the seat in a rearward facing position. Good luck.http://www.ehow.com/how_7624391_instructions-cosco-alpha-omega-elite.html
Jul 25, 2011 | Cosco Alpha Omega Elite 5-Point 22-155
Looking for an online car seat manual for my Alpha Omega Elite (2007). Cannot find with general searches. Any suggestiions?
Go to the site thru the link below. Put in your model number and date of manufacture.
It will give you the manual.
Alpha Omega Lookup
Mar 29, 2011 | Cosco Alpha Omega Elite - Hammer Print
Need info on running car seat belts thru properly for rear facing placement?
Use this site and input your model number and date manufactured to get your manual.
If it doesnt have your manual you can call 1-800-544-1108 for Dorel and have one
emailed or mailed to you.
http://www.safety1st.com/usa/eng/Instructions?ProductNumber=22456CAO
Mar 12, 2011 | Safety 1st Alpha Omega Elite 22456 TTN...
How to remove base off of Safety 1st Alpha Luxe car seat?
How do you get the base off of the saftey 1st alpha omega elite car seat ?
Sep 28, 2010 | Safety 1st Alpha Omega Elite 22456 TTN...
I have a cosco alpha omega elite car seat that i bought yesterday and i figured out how to put in in my car but i can't figure out how to take the base off for front facing.
Specs Released 3 years ago Restraint System 5-Point Safety Harness
Adjustable Harness Height Adjustable Harness Height
Car Seat Type Convertible
Additional Features Latch System
Adjustable Recline Positions Adjustable Recline Positions
Carry handle No Carry Handle
Head Protection With Headrest
MPN 22155HMR
Seating Direction Rear / Forward Facing
Stay-in Car Base No Detachable Base
UPC 044681223853
Weight Limit 5 - 100 lbs
Sep 08, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Need a manual for cosco alpha omega car seat
You can input your seat's model number and date of manufacture from the label on the seat itself at Cosco's website to download the instruction manual at http://www.coscojuvenile.com/instructions/
Sep 05, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Removing car seat
Someone told me to learn how to operate the latch system. It can be found on this site: http://www.youtube.com/watch?v=ee0lRogRO98
Some other links that were helpful:
http://www.kidsinsafeseats.ca/pdf/uas.pdf
http://www.thecarseatlady.com/vehicles/the_latch_system.html
Dec 06, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
How do you install the car seat for rear facing?
Hey Just posting this for future reference for other people since I see that you posted over a month ago :) ..
To install the car seat in rear facing I used the latch system. (you can use the latch system if your vehicle has latches..they are tiny metal bars in between the seats)
First of all with this dumb car seat I found out that the latch system was not in the proper place so if you find that yours is not where the diagram shows (in the manual) then you'll have to take off the seat cover and manually put them in their place. Then go ahead and clip onto the latches in the rear facing position. If the car seat is too far forward then inline the seat. If the car seat is still not leaning far enough back to be level with the ground (there should be two level marks on the top/side of the car seat) place a rolled towel (or roll a 2x4 in a rolled towel like i did) then clip onto the latches. Hope this helps someone.
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite car seat
Manual is available at the manufacturer's website
Mar 19, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite 5-Point 22-155 Logo
952 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
