HP Compaq Presario V2000 PC Notebook
Problem for HP Compaq Presario V2000 PC Notebook
Overheating
By Incredible on Dec 26, 2006
My compaq Presario v2000 has been giving me a problem. It heats up and then shuts down 15 minutes after starting up. Is this something that others have faced? Does this require fan replacement or is it likely to be a CPU problem as well?
Same Problem
Feb 02, 2009
-   i have the same problem, but am having trouble disassembling the laptop. it is a dl70. does anyone know how to do this?-   mmaatt
Jan 01, 2009
-   It's definitely a 'cheap thermal grease' issue. If they used arctic silver in the factory, we likely wouldn't be having these problems. Not as much profit margin though, to do it properly ;)
I might do this tonight, if I can find my thermal grease... -   Guest
Nov 26, 2007
-   My compaq presario, V2615 to be exact, also shuts down during use at about the 15-20 min mark. I was suspicious of overheating since it won't turn back on for at least another 10-15 minutes after it shuts down. I will double check my fan. Thanks!!
-   Guest
Best Solution
posted on Jan 07, 2008
Helpful)
Nitrotrike
Rank: Guru  HP Expert
Rating: 88%, 832 votes
This is an easy fix if you're comfortable with taking your laptop apart. What has happened is the thermal grease in between the cpu and the heatsink has dried out, and is not conducting the cpu's heat properly. The machine is shutting down to protect itself. My best advice is go to any computer store, and get a tube of thermal paste, and find the disassembly instructions online. Clean both surfaces (the heatsink and cpu) with rubbing alcohol. Re-apply a thin layer of new thermal grease, and reassemble. Be sure to clean the crud out of the heatsink while you have it out.
Was this helpful?
Yes
No
Solution #2
posted on Jan 02, 2007
Helpful)
Zekster
Rank: Apprentice
Rating: 90%, 1 votes
Check for BIOS updates at the Compaq support web page. I have a similar V2555US model and there was a BIOS update to fix a problem where the cooling fan wasn't coming on when it was supposed to. After the BIOS update, the fan works perfectly.
Was this helpful?
Yes
No
Solution #3
posted on Dec 26, 2006
Somewhat Helpful)
tomj23
Rating: 87%, 1820 votes
The cooling fan should automatically kick in before the laptop shuts down.
If the fan is turning on then you should feel a warm breeze of air being forced out of the bottom left hand part of the laptop. If the fan is on but no air is felt then you might have a dust blockage. You can try blowing it clean with canned air but you will probably have to disassemble and clean.
If the fan isn't coming on or the blades move very slowly or stop then your fan is probably defective or clogged badly. Again try cleaning or if that doesn't work replacing the fan.
Looks like the fans run about $50 to $70, however, don't attempt disassembly unless you are confident you are up to the task. This isn't a particularly hard job but you will need to remove screws and mess around with fragile plastic parts, not a task for the typical computer user.
Good luck and let us know the outcome.
Was this helpful?
Yes
No
Solution #4
posted on Jan 29, 2008
Not Rated)
matt10291
Rank: Guide
Rating: 80%, 3 votes
yes its probably the fan but it could also be the screen brightness. replacing the fan and turning down the brightness will cool the laptop. but i agree try a new fan first.
Was this helpful?
Yes
No
Solution #5
posted on Aug 02, 2007
Not Rated)
nickhardman
Rank: Guide
Rating: 94%, 9 votes
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE.
The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared.
If you are computer savvy, then try the following - if not, take it down to a computer shop!
1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back.
2) Remove the 3 screws which hold in the heat sink in place.
3) Remove the heatsink
4) Take the dust out
5) Re-assemble
a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario V2000 PC
Questions and Unsolved Problems for HP Compaq Presario V2000 PC
Do you recommend HP Compaq Presario V2000 PC Notebook?
Answer
Answer
I have a compaq presario XP machine with a synaptics touchpad. I turn of tap click but it gets... (More)
Answer
instale windows 7,en mi compac empresario,pero no tengo el controlador de video,me puedes ayudar,soy... (More)
Answer
How do I stop or adjust the scroll feature on my touchpad ? I tried messing with the mouse in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
