Question about Pix Cameras
Camera will not turn on, says turn off camera and turn on again, but does nothing else
My camera all of sudden will not turn on, just a message with red exclamation point says turn off camera and turn on again, but does nothing else, can anyone help?
  • 1,679 Answers
Click on the link below to fix the Camera issue. This link will be helpful for you in future too
Troubleshoot Camera Issue
Regards,
Suhail
Posted on May 16, 2012
SOURCE:
SOURCE: My camera says "Turn the power off and on again"
My sister had the same problem and I was trying to figure out what it was so I googled it and someone suggested to take the camera and hit it (not very hard) with the lens side down on a table.....This may sound completely crazy but I tried it and it made a weird sound so I turned it off then on again and it worked!! Hope it works!
Posted on Mar 13, 2009
SOURCE: have fujifilm finepix f40fd. protected card shows. wont clear
I had the same problem with a Fufifilm camera. When I looked closely at the memory card I noticed a little white sliding button on the left hand side. When it is in the down position the card is locked or protected. Just slide the button up and put it back in your camera and it should work.
Posted on Dec 06, 2008
SOURCE: problem with sony cyber shot dsc- w80
I jeremy- i was having the exact same problem today. I phoned Sony repair, who then had me take out the battery and hold down the power button for about 30 seconds..reinsert the battery and power up. Didn't fix it. I came home and read some posts on here. I ended up trying the gently twist the lens as it was zooming in and out..I twisted a little and pulled a little. About the third time, it worked. (I also held the power button down with the battery in, just to try..maybe that helped, too). Sony wants flat fee of $91 to fix..is that what they told you?
Posted on Jun 09, 2009
SOURCE: Camera powers on, then off
My got fixed when I gave it 5 gentle, firm bangs on the carpet with the bottom facing down. Got the advice from somebody online, figured, it's already broken and about 2 years old so what do I have to lose? To me was less risky than trying to open it. The focus problem got fixed and so far no message. Worth trying
Posted on Feb 27, 2010
Lumix closes when turned on from drop
The message please turn camera off and then on again appears when the camera is not operating properly. So the manual says.
If the message persists you should contact the dealer or nearest service centre. But first you could check if you can see any damage. Check if the lens is not stuck. Remove the battery for a little while before you again try to switch on. Also check if the memory card is still in place and the battery door and memory card door are closed correctly.
If nothing helps you could contact the service centre or think of buying as new camera?
Jan 02, 2014 | Panasonic Lumix DMC-LS75 Digital Camera
Suddenly I keep getting the message "please turn camera off and back on again" but nothing happens when I do I just get the message again. I can turn the dial to view pictures but if the dual is turne
did you try to wait several seconds before turning the camera back on?
When it happens again, after turning off the camera please remove the battery for a few seconds and put it in again. then switch on.
If the problem persists goto the repairshop or your dealer.
Dec 23, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Error message
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Sep 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Panasonic dmc fx-10 digital camera -
The lens may be broken(barrel)replacing kost you about 175,00 euro
May 11, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
Cameras Logo
371 people viewed this question
Top Pix Cameras Experts
Marvin
Marvin
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Are you a Pix Camera Expert? Answer questions, earn points and help others
