Question about Bemis 4D7 300 5.5 Gallon Humidifier
Tanks not draining
My tanks are not draining into the humidifier. I have cleaned the screw tops and the little posts that they sit on in the humidifier. The tanks are creating their own vacuum and not draining so the humidifier is just blowing cold air instead of cold moist air. Do I have to buy new tanks?? or new tops for the tanks???
You may be over-tightening the caps. It's tempting to over-tighten because it's a big tank of water that you're about to turn upside down! I had the same problem and the fix turned out to be just that - take the tank(s) back out, loosen the caps (hear the Ssszzzzz as the vacuum breaks), now tighten the caps again, but just enough that the water doesn't leak, and no tighter. Get the cap snug, but not so tight that you couldn't turn it some more. Do it over a sink the first couple of times until you get the feel of it.
Posted on Dec 09, 2008
Why does my humidifier holmes 1700 blows air but no water or mist?
If the water has been sitting in the reservoir for days without use, it may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
Good luck
thebqe
May 04, 2014 | Holmes Products Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Cleaned product and keep get reset light and also will it operate without the water tank cup
The valve on the bottom of the tank is either too tightly twisted on or needs cleaning. Be sure when you push up on the little plastic piece that sticks out that the water comes out quickly (do over sink). If not, loosen the filling cap, clean the valve and screw cap back on, but not too tight.
Nov 03, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
How do I replace the filter 14909 for the Kenmore Humidifier 758.14407
Fairly easy.
Unplug the humidifier.
Make sure the electric cord is free to move.
Remove the water tank and set aside.
Then lift the top of the console upwards. The top
just sits over the body, no latches. You will see a hood that
fits over the filters... lift this up. Filters just lift out and are
easily replaced.
At the same time, clean out the bottom pan... it gets yucky.
filter p/n is 42-14909 or E2R..available through sears.com
OR filters-now.com. Replace 2x per year
Nov 25, 2009 | Kenmore Humidifiers
Continuous water draining from my General 1042 Humidifier.....
This type of humidifer is known as a flow through humidifer, when running water flows through it instead of sitting in a pan. The water draining is normal. This type of humidifer will use more water than a pan type but is much healthier due to the fact that you do not get all the build up of the pan type if you ever cleaned one. also change the water panel every year. to change the water panel there will be 2 screws on the bottom pan. Remove them and the panel will come out, buy a replacement at home depot or such store if available, otherwise from a htg company. Replacement is a little tricky to get it to line up so be patient. If you cant remove the bottom panel due to lack of room, it will come out through the top. You will have to loosen and swing the water feed tube out of the way. That is the only maintainace to this humdifier. Also with this humidifier all you have to do is turn the humidistat to off in the summer, you do not have to turn off the water as with float types. Steve
Nov 28, 2008 | General Filters 1042-LH Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Clean
This is the link to your manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
CAUTION:
Always be sure that the appliance is unplugged and switched OFF before cleaning or attempting to store the item. NEVER PLUG OR UNPLUG UNIT WITH WET HANDS.
DO NOT leave water in water tank or water basin when unit is not in use as it may result in the build up of mineral deposits and bacteria that can inhibit the output efficiency of the humidifier.
PLEASE NOTE that if water remains in the water tank for more than a day or two, bacterial growth is possible.
ALWAYS use fresh cool water when using unit.
NOTE:
When removing water tank, water may accumulate under vapor lid and on the bottom of the water tank. It is recommended to have a dry cloth ready to dry wet surfaces.
DISINFECTING THE WATER TANK AND WATER BASIN
1. Fill water tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty minutes, shaking vigorously with two hands every few minutes, drain and rinse with clean water until the bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the water basin with a soft cloth dampened in the bleach and water solution. Rinse the water basin with cool water to remove any bleach smell. DO NOT IMMERSE WATER BASIN IN WATER.
3. Wipe all exteriors surfaces of the base with a soft, dry cloth. Do not immerse the base in water or use water to clean the base. An electric shock may result or the humidifier may be damaged.
NOTE: It is recommended to clean humidifier with water and bleach solution as stated above after using the humidifier the fourth time.
GENERAL MAINTENANCE AND CLEANING
Before any cleaning operation, switch the humidifier off and unplug it.
1. Always unplug the unit before cleaning.
2. The humidifier must be drained and cleaned before storing.
3. Once unplugged the exterior of the unit may be cleaned by wiping with a soft dry cloth. Caution: The ON/OFF switch must be thoroughly dry before unit is again plugged into power source.
4. There may be some lime deposits in the nebulizer, particular in areas with hard water. Overcome this drawback by cleaning the nebulizer with water and vinegar on a soft cloth regularly, as follows:
A. Dampen a cloth with vinegar and wipe the nebulizer gently, until the lime deposits disappear completely.
B. Rub down gently with a dry cloth and remove remains of humidity.
C. Do not rub the nebulizer with solid objects.
D. Do not clean with chemical products
5. When cleaning the water basin do not place the nebulizer directly under the water tap.
6. Never immerse the unit in water or let water enter the fan vent (see figure 3) or any other openings.
7. It is normal for water to be in the water basin. However water must not get inside the central body. If this should happen, take the humidifier to an authorized service center before using it again.
8. Clean the inside of the water tank at least once a week, as follows:
A. Fill the tank with clean water adding a few drops of bleach. Close the tank completely with its cap and shake by holding the tank with both hands. Do not hold by handle while shaking the tank.
B. Rinse thoroughly.
Water Level Sensor- The water level sensor is made of three key parts. When cleaning DO NOT MISPLACE these parts and MAKE SURE that you assemble these three parts correctly after cleaning and before operating humidifier. They are as follows:
Plastic Cap – this part has 4 flat tabs coming out from the bottom and is placed on top of a plastic pin.
Water Float - a small round part resembling a "life saver" candy located underneath the plastic cap.
Pin – plastic pin that secures water float and plastic cap.
To clean the water float unscrew the plastic cap from the pin. Remove the water float and clean by wiping the parts with a soft damp cloth. Replace the parts by first putting the water float onto the pin and re-screwing the plastic cap onto pin.
Good Luck.
Apr 01, 2008 | Crane Penguin 1 Gallon Humidifier
Cleaning instructions
I was looking for instructions as well, because I thought I had lost the manual. But then my wife found it. According to pages 8-9 (I scanned the pages as well and posted it here):
CAUTION:
PLEASE NOTE that if the water remains in the water tank for more than a day or two, bacterial growth is possible.
NOTE: When removing water tank, water may accumulate under vapor lid and on the bottom of the water tank. It is recommended to have a dry cloth ready to dry wet surfaces.
3. Once unplugged the exterior of the unit may be cleaned by wiping with a soft dry cloth. Caution: The ON/OFF switch must be throughly dry before unit is again plugged into power source.
Nov 12, 2007 | Crane Cat EE-3187 1 Gallon Humidifier
Bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Sep 23, 2007 | Bionaire BCM6010 Humidifier
Left Tank won't empty
Eureka! Solved my "left bottle not emptying" problem. The problem was not with the bottle but that the top of unit which houses the on/off switch was not seated properly. It takes only a very slight difference in water level for the float to activate the switch, therefore if the top is raised even 1/4" the unit will shut off before the water level is low enough to allow the left bottle to drain.
Feb 26, 2007 | Emerson HDC12 Humidifier
Bemis 4D7 300 5.5 Gallon Humidifier Logo
216 people viewed this question
Top Bemis Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
