Question about GE WBSR3140DW Top Load Washer
Leak into washer
There is a small water leak into the washer when the washer is not in use. The leak is coming from where the water comes in when the washer is in use.
  • vcrossett Nov 22, 2008
    my husband already tried this and it continued to leak after turning the cold and hot water supplies off.
    New Friend:
  • 128 Answers
The solenoid for the water intake is faulty. It may just have some crud stuck in it. You have two, one for hot and one for cold connected directly to the hoses on the back. You can shut off the cold water supply and see if it still leaks - if it does the hot water solenoid is faulty - if the leak stops then the cold water solenoid is bad.
Posted on Nov 22, 2008
  • mpservices Nov 22, 2008
    You would have to turn the valve off for a short period of time - until the pressure bleeds off.
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Pressure washer itseld turns on
I'm guessing that you have a small electric washer. These come on when triggered.....or if there is a water leak on the high pressure outlet side, at a connector or the gun itself...or possibly some internal leak. It's not likely being worth the cost of a repair if it is something beyond a simple leak. Commonly, the washer will only come on in short pulses. Coming on and staying on would be an internal switch problem unless your high pressure leak is substantial. Leaks are usually just worn, split or missing o-rings at the connectors.
Oct 20, 2012 | Garden
Dish washer starts ok then check water light comes on. if you reset the m/c it then starts ok but then the check water light comes on again.If you lightly shake machine from side to side the water starts...
This could be a slight water leak that causes the "anti-flood" system to kick in. This device is a polystireen float and a micro switch at the bottom of the washer. Once a small bit of water has leaked it causes the float to rise and activates the anti flood device that just puts the washer in pump out mode and nothing els. You could try tilting tha washer to get rid of the water at the base or dry it if you have the washer open (front or back). The cause is normaly a slight leak on a clamp or a very small hole in a pipe or can also be a rust speck inside the washer that causes the leak. You need to check the float to see if water leak is the problem.
Jul 19, 2011 | Dishwashers
I have a GWL11 washer that has a small water leak that appears to be clean water. I looked underneath and couldn't see where it was coming from.
Sometimes water can leak from the hoses where they join the taps and/or the water inlet valves..Check for leaks by running you hands along the hoses and unions. Or there may be a problem inside the area behind the display panel...Unplug at wall and remove the 2 screws at rear of display panel. You may have to remove the lid by sliding it upwards while on the open (vertical) position..sometimes the mixer box leaks where the temperature sensor probe connects...Good luck...Nomess
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Leeking water from some were not from hoses
Leaks on this model washer can commonly be determined by the following:
1. If the leak is coming from the from underneath the front center of the washer, it's usually caused by a leaking water pump. If the pump leaks, it is not serviceable and must be replaced. The following link explains how:
http://www.fixya.com/support/r397094-replacing_water_pump
2. If the leak is coming from the central area under the wash tub, the tub seal may be leaking. You should see tell-tale signs of water tracks on the gearcase (transmission) if this is the case. Also inspect the wash tub for cracks. Since the outer tub is usually made of plastic, it can crack and develop leaks. This repair involves removing the tub. It's not difficult, but can be extensive. We'll cross that bridge if the time comes - post back and let me know and I can give you advice on how to repair and the parts you may need.
3. If the leak is coming from the right-hand side of the wash tub, consider the air dome. This is a small dome located on the lower side of the wash tub with a small air hose attached. This is how the pressure switch is able to determine the pressure change as the tub fills and turn the water off when full. This air hose can come loose, causing water to pour out while filling (THIS IS NOT A SMALL LEAK). If the air dome is till intact with no cracks the air hose can simply be reattached. If the air dome is damaged, the tub will require replacement.
4. If the leak is coming from the rear of the washer, you will need to check your water inlet valve and associated dispenser hoses. The following link explains how to access the valve and replace (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Of course, your drain hoses are always suspect. You mentioned those hoses weren't leaking. However, if you have not removed the washer case and inspected them closely, you may want to double check them.
If you have any questions, please let me know. I hope this helps you locate your problem.
Jul 18, 2009 | Whirlpool LSR5132PQ Top Load Washer
Tromm Washing Machine small leak
Front load washers will always have some water in them. if, it leaking out, you may either have a bad seal, these are double drums, you may have a leak at the discharge house coupling at washer
Jul 02, 2009 | Washing Machines
Small leak/drip at on the front side of the washer..
possibly water pump you need to get fix asap cause it could start fire!!! Good Luck!!!!
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
149 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
