Question about Whirlpool Dryers
The felt part of the dryer filter keeps coming out. Now it won't even stay in when I put the filter back in the dryer. How do I fix this.
    Sergeant:
    Champion:
  • 324 Answers
Replace the felt seals.they glue onto the drum
Posted on Nov 22, 2008
    Problem Solver:
  • 6 Answers
FELT PART? Are you talking about something that is gray in color, against a wire mesh screen? If so, that's not called felt, that's called lint.... and you clean it out and discard it after every load.
My Whirlpool AWZ233 clothes dryer keeps stopping before the clothes are dry.
check vent line and or clean vent line inside dryer, clean vent line. Felt is probably drum seal.
Whirlpool AWZ233 Tumble Dryer Parts
Apr 20, 2018 | Whirlpool Washing Machines
How do I replace the felt seal
Most felt seals are glued in with a hi temp glue. Without seeing it I can't be sure but I think the drum has to come out to fix it properly. The glue can be purchased from most parts suppliers and sometimes comes with the new seal.
Mar 30, 2015 | Kenmore 700 6972 Electric Dryer
My frigidaire gallery electric dryer won't turn on. In the past it has been a bit on the noisy sound with a squeaky sound coming from the back. The last time I went to put a load in the dryer the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Frigidaire Dryers
Felt can out of the dryer
Are you cleaning your lint filter regularly? If not, the felt is probably lint that has accumulated inside the dryer as a result. Clean the lint filter, and if necessary, clean the vent hose to allow good air flow and this should take care of the problem.
I hope this helps. If it does, please come back to Fixya and rate my advice!
Jul 28, 2011 | Dryers
GE DPSR483EA Electric Dryer was making a scraping sound when operating, now a felt like belt has come out on the inside of the dryer. what do i do? Kris Long
The problem is something got between the drum and the felt seal between the drum and the front of the machine. You will have to pull the front off and find out what caused the felt to come out and then put the felt back in place and put the front back on.
Mar 18, 2010 | GE DPSR483EA Electric Dryer
Maytag Dryer Mosel #MDE6700AZW
you will need to remove the front panel and the front bulk head. after that you will see that there are clips that need to be pushed down to hold the fabric (felt) down. You need to make sure that the felt isn't torn. If it isn't torn then all you need to do is take a flat head screw driver pry the clips up and put the felt back on and push the clips back down
Dec 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Clothes get lodged between dryer barrel and dryer frame
you need a new rear bearing kit and a new top front felt yes this is something you cand yourself. Frist unplug the dryer, with a stiff putty knife releace the clips on each side of the top at front to pop open the top. next on the inside of the front cover on each side is a philips head screw remove both screws ( I find it easier to use a #2 square head for this ) now remove the front panell diconect the door switch.now reach under the dryer drum behind the motor and release the belt by removing the tention on the idler pulley and slipping the belt off the motor shaft (you may be able to do this better fromt the rear of the dryer. there is an access panell remove the two screws and you can see the belt and idler pulley ) now using the belt in one hand and the front of the drum in the other lift up on the rear of the drum ( you are lifting the bearing out of the scocket you will feel it pop out ) now slid the drum out of the cabnet. Now you can repace the bearing put a piece of duct tape over the clip on back center of the dryer ( on the outside ) now remove the two 5/16 screws holding the bearing cup on remove the tape from the clip put ne clip on tape in place set new steel ball in cup i put a dab of the greace supplyed in the kit to hold it in put cup on new bracket. set in place and put screws in you may have to reach around the back to line up the clip teghten screws snug. now in the center of the drum is the bearing on the inside are three philips head screws remove all three some timse you can use a #2 square headi lossen all the screws frist almost completly the remove them one at a time or you will have to hold the bearing with one hand to keep it from spinning. Putting the new bearing on you have to put the screw in one hole hold it with one hand and line the bearing up with the other or get some one to leand you a helping hand makes it alot easier.tighten all three screws good and tight now reinstall dryer drum besure to seat the bearing in the bearing cup again you will feel it pop in put the belt back around the drum. Now on the dryer front you will see the felt support the fron of the drum glides on pull it off just the top felt only with a putty knife clean off as much of the old felt as possable. Apply a genurious amount of the glue provided in the kit to the new felt i always put a good line of glue on the dryer front also press the new felt to the front (be sure if the new felt has plastic glides the overhang should be toward the front not the drum if the new felt does not have these glides you don't have to worrie) put dryer front back on when putting the drum back on the top felt you may need to hold the new felt to keep it from moving. reconect door switch put the two screws back in the front. now go back to the back and putthe belt back on the motor pull the idler to tighten the spring put belt around motor shaft and ease pulley back to belt. Put access cover back on and secure. close the top plug it and test don't let dryer run long just a few seconds I like to let the dryer set 24 hour befor putting back to use to give the glue time to set.
Nov 23, 2008 | Frigidaire FEQ332E Electric Dryer
Black marks on clothes
Your going to have to get service for this one. Chances are the rollers are gone and the black is coming from the rubber onto the felt and then transfering to your clothes.
Sgt 48
May 11, 2008 | LG DLE2514 Electric Dryer
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
197 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
