Kenmore dryer runs but does not heat
If the dryer runs - but no heat is produced, there are usually two things that it would normally be - first turn the dryer on and go outside and check the flow at the duct. If the flow at the duct is weak (should be nice and strong) then you more than likely just have a clogged up duct - clean it out and you should see a big difference in airflow and time to dry things. If the air flow is good but there still is no heat - you may have a heater bank that went out, or a hi limit switch that was set
gas dryer runs but igniter will not come on
I have the same problem. How can I check the high limit switch?
the dryer runs just fine, but has no heat. Everything else is functioning normally.
