Question about Brother MFC 1950MC Printer
Cannot get dial tone on phone
Mfc brother 1950mc
  • rickrussell6 Nov 22, 2008
    The unit is 10 years old.
    The unit has been kept clean and has been working.
    I was faxing papers long distance the machine stopped in the middle of the fax 52 pages and I tried to redial but could not get a dial tone.
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    Is this a new installation or has the unit worked in the past? Has anything been moved or changed around when the problem occured?
    Sergeant:
    Champion:
  • 274 Answers
I would suggest unplugging the unit and let it sit for about 15 minutes. Make sure there are no paper jams, and then plug it back in and turn it on. Also, check the phone line with another phone instrument.
Make sure to put the phone wire back in the right port.
Plug in and power the unit back on and test it.
If it is still failing, then I am sorry to say that it might be time to get a new unit.
Posted on Nov 22, 2008
Not able to get a dial tone on my fax..I've checked the phone line and reset to factory default and still no dial tone...MFC-210C / MFC-420CN
try to check the line connection at the back it has two inputs line and phone connect the wire from wall to line input then the phone input to a phone unit ..you better put a phone extension so you can hear or check if it has a dial tonemarmeto12_1.jpeg
Aug 18, 2011 | Brother MFC 210C All-In-One InkJet Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
When I plug my fax into the phone line, my phone line goes dead to all other phones. Never had this happen before. Help
make sure the fax machine slot is not short .remove all the parale line connection and just conncet the fax in to line and check you are gettting the dial tone.
Jan 14, 2010 | Brother MFC 1950MC Printer
How can i fix the troubleshooting and routine maintenance problem on my brother mfc-7340, i cant receive fax or send.
Plug a phone into the jack and see ifyou have dial tone. if you do then check to see if yo have dial tone when you select hook on the printer. If you do have dial tone then make sure you are pluged in the back in phone not ext. if that is not it then make sure you unit is on fax only.
Jan 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
No dial tone to fax documents with Brother Model
This issue was addressed previously by another FixYa expert. Read the entire post before attempting any repairs. Hope this helps
See:
http://www.fixya.com/support/t1234332-mfc_440_cn_out_memory
Dec 11, 2009 | Brother MultiFunction Center MFC-440CN...
My fax onmy mfc is beeping when i dial and press start there is no dial tone when i press hook is it connected?
If it is connected you would hear a dial tone when you press hook. There are 2 possible places to connect the phone line, the proper one has an L on it and the other a picture of a phone that is for a phone or answer machine.
Nov 18, 2009 | Brother MFC-5440CN All-In-One InkJet...
No Dial tone for fax
Did you choose the right input for fax? Or did you connect to the phone line in at the mfc? Did you choose the right settings? See handbook for that.
Sep 07, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 1950MC Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
