Graphics Publishing and Multimedia Software
Problem for Graphics Publishing and Multimedia Software
Generic problem for all Graphics Publishing and Mul...
Error messages when i try to access Pho...
By suek9fan on Nov 23, 2008
I have used this program w/ problems till this past week ... no changes were made to computer setup as far as I know to cause my problem !
OK here is my problem ... I have Photo Explosion Deluxe Version 3 & now when I click on the icon on my desktop the title page w/ name of program pops up normal the I get this error
Photo Exploson: Ipe.exe Application Error
The instruction at ''0x7c910ed4'' referenced memory at ''0x79706f3b'' The memory could not be ''read''.
Click on OK to terminate
Clinck Cancel to Debug
I click OK then another error box pops up like the other except it has this instead
The instruction at ''0x715a3028'' referenced memory at ''0x15f10001'' The memory could not be ''read''
NOBODY has been able to help be cure the problem ... Nova Development or Microsoft support have been no help ! this one will probably stump ya'll too but I thought it waas worth a shot since this is my fovorite program to play w/ pictures with & its easy to use ! I have 3 versions & even tried Version 3 but I got the same error messages . I have used all the versions for several years & this is the 1st time I've ever had a problem . HELP ! Thanks for any help whether it works or not !
Comments:
Nov 23, 2008
- I've already tried this probably 10 times ! No luck . Here are a couple pictures of what i always get !
then after I clink OK I get this box
Nov 23, 2008
- I've tried lots of things but no luck so if anybody has any ideas please go right ahead ! Thanks
Nov 23, 2008
- I've tried this with no luck .... my computer has never wanted to go back to restore points & right now the last restore points are in the last few days & my program wasn't working then .
Nov 23, 2008
- Just wondering ... could DirectX have anything to do with my problem cause I remember for some reason I was suppose to upgrade DirectX & it wouldn't so I forgot about it & it was in the right time period that my problem started ... here is a picture of what I get when I try to upgrade DirectX
Nov 24, 2008
- still no luck w/ either error
Nov 24, 2008
- OK ya'll I keep doing what ya'll say to do & keep getting more error boxes so I'm gonna post the new error boxes & please tell me how to fix everything back . I do not know alot about computers so keep it simple ..thanks for all the help so far but nothing is helping .
Nov 24, 2008
- here are the new error boxes & in answer to one of ya'lls solutions I haven't found any viruses on my computer . The 1st is an empty black box that has C:\Program Files\Nova Development\Photo Explosion Deluxe ... should this box be empty ? It pops up at the end of my installation for a few seconds .
The next box pops up 1st now whenever I try & open the program & it looks like its part of my program so how do I get it fixed ? I close it then the other 2 origional ones pop up . Please give me a simple step by step way to fix these things . Thanks
Nov 24, 2008
- HELP ! If everything keeps getting worse I might have to quit !
Nov 24, 2008
- nope still nothing
Nov 24, 2008
- Please read all the problems ... LOL solutions instantly appear as soon as I repost & its not possible to read & post answers that fast !
Nov 24, 2008
- Again .. i've tried this & it doesn't work .
Nov 30, 2008
- None of your suggestions worked & really only made matters worse so this was a total waste of time & money . LOL I have more error boxes now than when I started !
Same Problem
Jan 28, 2009
-   same problem-   Guest
Solution #1
posted on Nov 23, 2008
Somewhat Helpful)
iwillfixit54
Rank: Guru
Rating: 85%, 63 votes
Fully remove the program from your computer and then do a fresh install from the cd/dvd
Comments:
Dec 01, 2008
- start from a clean plate, reinstall windows, empty the computer by formatting the hard drive in the setup and start over.
Was this helpful?
Yes
No
Solution #2
posted on Nov 24, 2008
Somewhat Helpful)
cation007
Rank: Wiz
Rating: 84%, 87 votes
Hi, First do the disk error check.
You can do this by going to My Computer, Right click C drive, goto properties.
and do a disk check.
Once done. Runt the IPE and see if it works. if you see any problem. Uninstall the IPE. download this software and run it. http://www.ccleaner.com/
Install the IPE now.
Hopefully it works.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
dahaka
Rank: Guru
Rating: 86%, 392 votes
Hello suek9fan,
Just reinstal the software (program) and see if that fixes your problem, if it dosent let em know,
Dahaka
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
Benimur
Rank: Guru
Rating: 88%, 3784 votes
Hi and welcome to FixYa,
Initially, try:
  • check/re-seat/clean/replace your memories;
  • increase your swap file size;
  • in Start, Run, msconfig, Startup tab, un-check any and all unnecessary programs such as notifiers, updates, monitors and the likes;
  • download, install and run Ad-Aware;
  • in Start, All Programs, Accessories, System Tools, do a Disk Cleanup, check all.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
smarttech
Rank: Wiz
Rating: 81%, 39 votes
its the virus causing any of the files getting corrupt, so because that file is corrupt it is not supporting the software u want to use and showing this error.your pc needs formatting to resolve this issue.but it is a very long procedure and after formatting you require all the other software cd to get installed if you dont have that cd to install the software.it is better to call a engineer at your place and get your pc formatted and the software loaded properly.it will not cost u more then his service charge for this call.
Was this helpful?
Yes
No
Solution #6
Somewhat Helpful)
acdr
Rank: Wiz
Rating: 81%, 931 votes
first go to start menu run "chkdsk /r" then press "y" then restrt the system.
then it check your memory.
.then go to my computer properties advanced.then again advanced second one then u see last option virtual memry
then set it to 1.5 * your ram size so if u have 1 gb ram the set it to1500 mb.
if problem remains then create new user in cotrol panel then enter in that user .then check on that user .
go to c: program files then search your soft foldr then openb it.
best of luck.
if u have software setup then first remove it completely then reinstall.
i give u link of software remover from registry.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Was this helpful?
Yes
No
Solution #7
Somewhat Helpful)
micromaster
Rank: Wiz
Rating: 82%, 758 votes
It's likely that another program is causing this- possibly legitimate-
possibly malware.
Take a look at any program that might be interfering with your software. You may have to reconfigure, update, reinstall, or not reinstall, a program.
Was this helpful?
Yes
No
Solution #8
Somewhat Helpful)
ginko
Rank: Guru
Rating: 89%, 5075 votes
Try first performing a system restore to a date before you had the problem for first time.
see:
How to perform System Restore on Windows
If this does not work, then reinstall Photo Explosion Deluxe, using the original CD.
Comments:
Nov 23, 2008
- If your computer uses two memory (RAM ) modules, try removing one ram module at the time, to see if one of the two modules is defective, or try a new mwmory stick.
If the RAM is ok, and you already tried reionstalling software, then the only way out is by reinstalling the system.
Was this helpful?
Yes
No
Solution #9
Not Rated)
rachelgeek23
Rank: Guru
Rating: 87%, 84 votes
Click this and download the program. Run it to check for virus infection and to correct what the virus changed. restart and try again to update direct x. If it still wont work try to run this. It will check services and other important things which could be disabled causing your program not to work. Restart and try again.
Pls post back if it still wont work. Good job in posting the progress of the issue. Once your issue gets fixed. pls dont forget to accept the best solution.
Was this helpful?
Yes
No
Solution #10
Not Rated)
leecom72
Rank: Guru
Rating: 89%, 2475 votes
the information contained in the registry about this software is corrupt and it will never work again unless you un-install the programme and clean the registry, there is a very good registry cleaning programme called CCleaner, here is the link:
http://www.filehippo.com/download_ccleaner/
once you have cleaned the registry, reboot the pc and re-install the software, this may work
I do have to warn you that because of what you have explained about the lack or restore points and the pc never being able to restore anyway indicates to me that the registry is more corrupt than i thought and the system is heading for more problems and will soon fail.
I recomend that you back up all of your data before this happends, because you are looking at recovery or windows re-install
hope this helps
regards
Comments:
Nov 24, 2008
- From a PC technicians point of view, there is no way to fix this problem apart from the way i described, and that is not guaranteed to work, the more you try fix it, the more errors you are going to get and the pc will crash!!!!
Its imperative you back your data up as soon as possible, you may think that what i am saying sounds drastic, but after working with PC's for five years i heave learnt to identify certain problems
regards
Nov 24, 2008
- After looking at the screen shots and reading what you are experiencing, i am in no doubt the registry is massively corrupt and the problems will now become more and more frequent until the system finaly crashes
Nov 24, 2008
- I recommend that you stop trying to fix the problem before you cause it to crash prematurely, you will not be happy if you loose all of your data
regards
Was this helpful?
Yes
No
Solution #11
Not Rated)
ohms
Rank: Wiz
Rating: 83%, 783 votes
re-installing didn't help (tried re-installing 1 version only ?)
have different versions (all use same executable filename ?, all have same error ?, versions installed have their own separate folder ?)
error happens to this application only ?
Windows OR Anti-virus Program's recent update might have prevented read/write access to some area of a memory which can be used for exploits.
Comments:
Nov 24, 2008
- Get the latest DirectX from Microsoft Downloads page. Install and let's see what happens.
Keep us updated. (interesting issue and would like to know what caused and what will fix it).
Was this helpful?
Yes
No
Solution #12
Not Rated)
taran_2005
Rank: Guru
Rating: 88%, 972 votes
Dude , This is an application error.
Certainly there might be a file that was deleted or corrupted ( Might be due to virus, uninstalling a software, any change in setting of windows :( ).........................
Uninstall and again install the s/w :) or if u know this file , download that missing file.
However, the best wld be to reinstall and uninstall teh s/w b'coz that wld make sure that all the files wld be there.
Thnx.
Take Care Bro.
Comments:
Nov 23, 2008
- Hey dude,
The problem was with Quicktime 7. steps are listed below:
Uninstall program
Reboot system
Right click on start button go to and delete the nova developement folder
Reboot system
Download **** cleaner, install and run it to get rid of the old registry files left behind.
If you have Quicktime 7.0 or higher installed go to add remove programs and uninstall it, Reboot system.
Now the installer from cd should run fine. after install I believe you will be asked to reboot, do so and run the program.
Thnx.
_uacct = "UA-229687-1"; urchinTracker();
Nov 23, 2008
- Name od the software - **** Cleaner....Dude link is working :)
Thnx.
Was this helpful?
Yes
No
Popular Solutions for Graphics Publishing and
Questions and Unsolved Problems for Graphics Publishing and
Answer
It takes for ever to install the program than it does not open....I have Windows XP
Answer
serial: 1045-1090-6246-8353-3166-2968 activation: 4074-8422-5215-4092-0267-4342-4063 activation... (More)
Answer
need to install macromedia authorware and it keeps saying access denied. How do I download it
Answer
I cannot open any of my Microsoft picture It publishing platinum 2002 projects
Answer
i have this problem all the time. never finishes rendering. i take the whole thing apart,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Graphics Publishing and...:
Top Graphics Pub... Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Graphics Pub... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
