Question about Toshiba Satellite M35X-S111 Notebook
SD card (not SDHC) at 4GB=ONE gig?
SD card. The proper clean-up is to clean FORMAT the
SD 4GB drive,
Surprize= it returned = ONE gig only. (residual size "saved")
4 GB into ONE gig : is the problem
SDHC is not reliable and is not compatible with many systems.
I use only SD=only cards, very reliable, fully interchangeable.
I ASK YOU TO LOCATE FOR ME, EXACTLY where from I can
download a FORMAT (factory) software to "re-activate"
this 4GB drive back to its original 4GB.
and, or, whatever this software will DO, to make it so.
Tell me or give me the software, where is the download, exactly.
No arguments, no discussions, opinions or detours, Exactly where, or provided, if you can, by you, the experts in the field.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Site for Hex Editor you need
HexEditor. http://www.sweetscape.com/010editor/
Instructions
Put your card in card reader and run the Program.
Choose "Open Drive" from the Menu and select the Physical Drive of your SD-Card.
Choose "Edit" -> "Select Range" from menu.
Start Address: 0
Press OK
Select "Edit" -> "Fill Bytes" from menu
Start Address: 0
Hex: 0
Decimal: 0
Press OK
Save.
Put it out of your computer and put it back in
You will be asked to format the card, do this and it should be fine
Firmware update may be needed to read card - http://drivers.softpedia.com/get/FIRMWARE/
Search through and locate your Model and Brand of computer
Posted on Nov 23, 2008
My 4gb memory card showing 30.1mb and can't formatted
My 4gb memory card SD showing 30.1mb and can't formatted it{Transcend}
Jul 23, 2014 | Transcend TS4GSDHC6V 4GB Micro SDHC Flash...
I have not been able to format a scandisk memory card into my Easyshare kodak camera z612
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card can't be formatted, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 23, 2011 | Kodak EasyShare Z612 Digital Camera
When i install team micro sdhc 4gb memory card in kodak easyshare z612 it says format .i select format but it keeps asking to format or cancell
First check make sure the SDHC card is unlocked I'll provide a diagram for that also I just checked your camera's memory capacity and it's only good for a 1 gig SD card which if using an SDHC memory card might go to 1.5 stretch to 2gig maybe but not a 4gig. My first impression is you got to much memory card for the camera. You might be able to go to the Kodak site and download updated firmware to allow the camera to function with the larger card but that's a maybe as well.
Here are the diagrams
And the memory capacity chart for your camera
Feb 02, 2011 | Kodak EasyShare Z612 Digital Camera
I've tried formatting a new san disk 4gb card and still reads "unable to use card" what do i do?
You haven't told us what kind of camera it is, but I can guess at the problem. There are two possibilities.
1. Your camera will only read SD cards, not SDHC cards. You've just bought a new memory card, not noticing that it was SDHC. The new cards don't work in your camera, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
2. You formatted the card NTFS, whereas the camera needs FAT32. You can format the card using Windows, but there is a complication: Windows defaults to "NTFS" when formatting, but memory cards normally use FAT32. Before you attempted this, you should have connect the card, and checked the 'properties' on the drive that appears. It probably said "FAT32". In this case, you could have gone ahead and formatted the card, but be sure that you chose "FAT32" from the drop-down list. If you format it NTFS, your camera won't be able to read it!
In this case your solution would be to format the card again, but using the FAT32 format.
You might find it useful to check your camera on dpreview (dot) com, and see if the memory card type is shown as just SD or SD/SDHC.
Jan 20, 2011 | Cameras
Hello my camera doesnt accept hp 4gb sdhc card.when i placed card in, it says card error.... Also,i cant format when sd card is in and ''card error'' on screen...(my sd cards are brand new) plese give...
Okay we have a problem, to properly answer this question "we" collectively need to know what make and model the camera is. However one clue to your problem was that you said SDHC and 4gb.
I'm going to give you a diagram on the SD card type lock make sure it's in the correct position (not locked) Also the SDHC is a newer style memory card and 4 gig is a ton of memory for point and shoot cameras.
If the card lock thing doesn't work and you still can't format then I'm going to say that your camera can't handle the memory capacity of the 4gig SDHC memory card.
Don't panic yet, you may be able to go onto the camera manufactorers web site sift through the models and find the firmware updates for your camera. Updating to new firmware editions could open the possibilities of using a larger card.
Here is the diagram hope this is all that is needed.
Diagram
Jan 05, 2011 | Cameras
I just bought an hp 4 gig sdhc memory card for my kodak easyshare c743 camera. Will it work or should i return it?
The C743 works with MMC and SD cards, not with SDHC card. Your 4GB card will not work in it. You can return it or, if you have another device which can use SDHC cards, keep it.
Jun 29, 2010 | Kodak EasyShare C743 Digital Camera
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
SD vs SDHC Card in Aiptek ASDV2.4 Camcorder
No return the card before you open it and get a regular SD card! this card will not format in your camera! Please rate my answer!
THANK YOU!
Jan 15, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
Toshiba Satellite M35X-S111 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
