Question about Viking VGSC306-4B Gas Kitchen Range
My Viking range top grates are dirty
I have a viking range top and my grates are dirty. What is the best way to clean them?
  • Anonymous Feb 01, 2009
    my Viking grates and burner caps are dirty and I cannot seem to get them clean  Where do you find grate polish???
  • 42 Answers
Viking advises using nothing but warm soapy water. grate polish works very good to bring that deep black shine to the grates again
Posted on Dec 21, 2008
    New Friend:
Soak in ammonia for a few hours preferably outside. Coupled with elbow grease....good as new!
Posted on Oct 11, 2013
    Problem Solver:
  • 17 Answers
Try buying new grates at http://www.appliancepartsonline.net
Posted on Feb 04, 2010
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Should oven grates be left in oven during self cleaning mode?
It has been awhile but I believe the grates and side racks have to come out to even get it to go into self clean mode. Hope this helps.
Good Luck
Mar 12, 2011 | Viking Kitchen Ranges
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Multiple sparks when igniting one burner
have a 1997 model 2470 viking pop up camper , has a shower in stalled where does the used water come out ??
Jun 19, 2009 | Viking VGIC305-4B Gas Kitchen Range
New Viking Range oven grates don't slide in and out easily
did you use the self clean option with the grates still in place?
If so... you now have to oil them... like PAM.
Thats what we had to do
Hope it helps
Jun 04, 2009 | Viking VGSC306-4B Gas Kitchen Range
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
978 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
