SOURCE: hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
if anti back fire selonoid is disconnected how
are you getting fuel? if so ck selonoid again make sure it is open. should run
SOURCE: Stalling Craftsman LT 1000 Lawn Tractor
I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
SOURCE: I have a Craftsman 42 in. 15.5 hp lawn tractor
check an see if the cabuerator is getting fuel and check make sure sparkplug is getting continous fire from the coil
