Question about Toshiba Satellite M35X-S111 Notebook
USB to 25 pin printer
New laptop USB to (cable or converter?) to 25 pin printer
both machines excellent.
Need cable or converter.
Indicate exactly where/how fix problem &
where from Cable or Converter, model if available,
brand could be used, etc.
Need good info, real info. (and Source)
  • 61 Answers
Ok visit this site http://www.byterunner.com/byterunner/category=USB+to+Parallel+Adapters
Posted on Feb 16, 2009
Is there a fix to this problem with the officejet r40 hook up to windows 7 professional
First, You need a 25 pin to USB converter to connect your Printer to Win PC.
Then, you need to simply connect the printer to PC and you will find a printer icon in the Devices and Printers folder to print.
There are no drivers available from HP as this printer is old and HP no longer designs the drivers, you will be using the inbuilt drivers from Win 7 to use your printer.
Regards,
Suhail
May 13, 2012 | HP OfficeJet r40 InkJet Printer
Is there any way to get my 9-pin Wacom tablet to work on my all-USB input laptop? I have a Xircom 9-pin to USB converter, but there are no Win7 drivers for it that I could locate.
If I remember, most of the 9 pin dot matrix printers used either a 25 pin serial, or a centronix cable which terminated into a 25 pin for the PC side. They do make a USB to Centronix cable. I cannot guarantee it will work if your trying to use anything other than a PCL language for your print jobs.
May 18, 2010 | Televison & Video
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
I just installed my designer software onto a new computer that doesn't have a 25 pin printer cable, however, I bought a usb/25 pin cable and have the dongle attached...but the software says the dongle...
Your software still is looking for the 25 printer pin connection from the motherboard. I don't know computer set up from an engineering concept, but I do know that the usb connection you purchased doesn't work with that software. You'll need to either get the new software or a used computer with the printer port hook up.
Nov 01, 2009 | Husqvarna Designer I
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
to print using a usb port to the printer install a network card which can be obtained from any printer repair shop
Nov 23, 2008 | Dell 5100cn Laser Printer
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
After installing my vista can print perfectly well on test printout
Advise from http://www.bebo.com/andythoo
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
TMu220 serie 25 for usb
Hi
option 1 - buy a pci parallel card
option2 - buy a cable serial 25 to usb the cost is $30 dlls
Oct 26, 2008 | Epson TM-U220 Matrix Printer
Toshiba Satellite M35X-S111 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
