Question about JVC AV-32D305 32" TV
My tv was dropped and now the color is messed up how can i fix it
My tv was dropped while moving it and the color is messed up when it is supposed to blue there are patches of green and red or other colors depending on what the background of the show is. How can i fix this problem?
  • deeky01 Jan 29, 2009
    how do you repair the picture tube and how much would it cost
  • 2,992 Answers
Unfortunately, this can't be fixed without replacing the picture tube. The drop caused a piece called the shadow mask inside the tube to warp or break loose. When that happens, the red, green and blue beams in the tube don't hit the right places on the screen. There isn't any way to repair this kind of damage.
If you had professional movers doing the job, their insurance should cover some or all of the cost of repairing the TV (replacing the tube, that is) or replacing the set. I wish I could give you better news.
Posted on Nov 22, 2008
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
I have a Panasonic TH-42PZ77U TV and the video is messed up. The left half of the screen is inverting colors and has a static like color mess moving/jumping around that half of the screen. Any suggestions...
More than likely you have a bad X or Y board. The only solution to that problem is to replace the defective parts. Call the manufacturer and see if your TV is still under warranty. Most of the time if it is under warranty they can dispatch a technician to repair the TV. If not, and you have to fix it yourself you are better off replacing the TV as the cost of repair could easily exceed three hundred dollars.
Feb 28, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I unplugged my cable and tv to move it and when I plugged it back in the color has been very off. Yellow seems to be the dominant color and the contrast is really off. I've messed with the settings a bit...
Need a little more info.
What type of flat screen is it? Plasma, LCD, DLP or Rear Projection?
How is it connected to the cable box? HDMI, DVI, or Comp Video (RCA cables)?
Have you tried another video source like a DVD player? Do you still have the same problem with the DVD playing?
And finally, did it get handled a little rough, bumped hard, or dropped any during the move?
Feb 13, 2011 | Televison & Video
Colors are distorted on the sides. Help?!?! The TV has sat next to some speakers and has made the sides of the TV colors get all distorted (one side green and one side purple when the screen is originally...
all colored tv has built in demagnetizer and activates everytime the tv is power on.but there are instances that discoloration of screen due to magnettic effect cannot be remove by built in can buy a separate demagnitizer for use it you need to switch on the tv .plug in the demagnitizer to ac outlet point the demagnitizer in center of the screen/front press the butoon of the demagnitizer ad move it sideways and circles as if your wiping the colors repeat it untill the color is clear.
Good luck hope this could help you..
your rate is important to me..tnx...
Dec 30, 2009 | Philips Magnavox TP3285C 32" TV
Foggy picture
not worth it, likely been dropped and all the lenses etc are out, or just worn out from a hard life.
Oct 12, 2009 | Philips 9P5034C 50" Rear Projection...
My surround sound speakers where too close to my tv and now my colours are messed up what do i do to fix the problem?
Seems the magnetic field from the speakers has caused the color purity in the televisions screen to become discolored, You might try unplugng the set and moving the speaker futher away from the television, Wait at least 20min before cutting it back on, There is a degaussing coil surrounding your picture whis supposed degauss the set everytime you cut it on. Much like you seen on older computer monitors when you press the degauss botton the screen would suddenly go to a rainbow of colors and then return to normal. Depending on how long the speaker has been there you might have to call your servicer and have them come out and manually degause the set for you.
Sep 28, 2009 | Televison & Video
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
replace the converge ic's
Jun 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
JVC AV-32D305 32" TV Logo
530 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
