Sony Plasam TV
The Model # is 40S3000 - The volume shows on the tv that it gies up and down and the tv works with the cable box.
I tried to unplug everything and wain an hour but still no luck
Thanks,
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me".
May I inquire, your post "tv works with the cable box" means there is sound and picture on cable?
Posted on Nov 22, 2008
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to have picture,somethings on the screen,words mean ur tv still works.
Mar 24, 2010 | Zenith R56W36 56" Rear Projection...
Turn on tv on sound on my sony kdl-40s3000 can anyone give me a suggestion
cant get what you mean kindly repost and explain your tv problem in detail.
Mar 01, 2010 | Sony KDL-40S3000 40 in. LCD HDTV
Volume Problems Sharp Aquos LCD TV
Hello Mhursh,
You will have to go into the cable box's menu and adjust the volume control features there as the catv box can control the volume also which is what you are experiencing.
Good Luck!
Rich Lilja
Jun 01, 2017 | Sharp Televison & Video
Video won't show on my on my tv-PS3
can you get cable/sat. feed or dvd on your tv.......if not thers a problem with the tv......try unplugging tv if no pic comes through for about an hour....yes i said an hour this will reset tv back to factory default when you pulled it out of box.....if this does not work you might have to call a repair man
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Aug 19, 2007 | Hitachi 51F59 51" HDTV Projection...
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Too loud
I am assuming you do not have a "surround sound" system hooked up to your digital cable box, and that you have your TV volume turned down all the way and have not yet tried to adjust the volume on your new digital cable box. It might be worth a try to unplug your TV for about 15 seconds and try again. If the above is true and you can still not lower the volume through the cable box or the TV set, then I would have the cable people stop by to check it out.
Dec 18, 2006 | Sharp 25R-S100 25" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
