Question about Westinghouse SK-32H240S Television
Westinghouse SK32H240S TV will not show picture...
Attempted to hook up this TV to satillite reciever. Though sound came through, the picture did not. Also hooked up a DVD player. Same thing happened. sound came through, but no picture. Just black screen. Picture would "blink" on about 5 seconds after turning power on to TV, but would then instantly go to black screen.
I have no idea why. I would appreciate it if you could help me.
Randy
  • areoneoh Dec 30, 2008
    The problem is common, apparently. I've been searching around and its happening to everyone. It doesn't matter what you plug in, the screen fades to black. This problem NEEDS to be fixed.
  • 3 Answers
Some solutions to this same problem were posted here, hope this helps.
Posted on Dec 30, 2008
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I hooked my player up to my RCA tv, but it will not show a picture when I record a TV program. I have cable. What am I doing Wrong
You might have an INPUT going to an INPUT, or vice versa. Always make sure that an INPUT goes to an OUTPUT and an OUTPUT goes to an INPUT. If this is not the problem, then you have a faulty cable somewhere, test it and if faulty, replace it. Good luck to you!
Nov 27, 2009 | Philips Magnavox DVD/VCR Dual Player
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
I have just hooked up a dvd player to the TV, and we watched it one time just fine. Now when we try to watch a DVD we just get an audio sound for about 2 seconds, and then nothing at all. There is no...
have you attempted a different video source into the TV (Gaming system, another DVD player, Reciever)?
The issue may be that the cables you are using may be old, and are severely damaged. inside of those cables is a standard RG-59 Coaxial Line that is extremely flimsie.
try and use separate cables or a separate input.
If the input change works, is most likely the switchboard on your TV (Hardware) and will need to be serviced. Another option to use is a Video switch ($35USD), and not pay $300+ for system repairs.
Aug 27, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Aug 08, 2009 | Onkyo TX-SR606 Receiver
Dvd recorder to satillite
if your dish satellite has an extra A/V output or if your plasma tv has the outputs and the recorder has the same type input AUDIO/VIDEO jacks
Oct 11, 2008 | Televison & Video
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Televison & Video Logo
2,035 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
