My 07 xt 125 x just wont let me turn key in ignition. is it best to put in a replacement and where would i get one
SOURCE: XT 125 oil problem
the iol fill is the black bung on the engine right hand side anticlockwise to unscrew with fingers its right next to starter motor
SOURCE: changing the old ignition barrel
If the bolts are the allen/hex/torx kind with a dot in the middle, just put a small flat head in there and remove that dot, or go buy some security bits.
If it's any other kind of bolt, use a file and cut a flat groove into the bolt, then either use a chisel and light taps with a hammer, or use a flat head screwdriver to unscrew it.
SOURCE: yamaha xt 125 07 no speedo or rev counter any
This is a very common problem for the yamaha xt 125. I suggest that you either buy a new Heads up display or you take it down to yamaha and get them to fit another one, which i think might be free of charge due to it being a problem with the bikes.
