Question about Nikon Coolpix 4500 Digital Camera
Nikon 4500 latch will not hold door to storage card shut
Suspect the small plastic catch on the door has broken. The repair looks simple - two screws seem to hold the item in place.
1) Can it be repaired easily as I susptect
2) where can the part be obtained
3) where can it be sent for repair if it cannot easily be done
PS: Camera works fine otherwise, but the loose door is annoying.
Thanks very much for your help.
  • 4 Answers
1) No, the screws do not hold the hinge itself in place. the door hinge is integrated into the CF card reader. the screws hold in the reader.
2) no clue, sorry.
3) no recomendations, but there are lots of authorized nikon repair centers online.
good luck.
Posted on Dec 10, 2008
How do I open my cool pix battery door when it appears to be stuck?
mine is a CoolPix 4500. Looking down on the battery door the
release catch operates inwards towards the camera body.
mine has 2 metal tongues that engages with loops on the body to
lock the battery compartment. could be corrosion in the latch.
mine comes to bits with 3 small phillips screws but only accessible
from the inside! A very gentle spray with WD40 might help, best plan
spray a little into the cap and then apply sparingly with a sharpened
matchstick, leave to stand for a while, the body on mine is not
plastic but aluminium/magnesium alloy which could give corrosion
problems especially with salt water? if it is metal could zap it with a bit
of heat from a soldering iron be careful and patient a very fine bit of kit
Oct 19, 2014 | Nikon Coolpix 4300 Battery Door Cover Lid...
Door wont shut
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Miele Dishwashers
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
The door on my bosch hmt8655gb wil not shut please can tell me the best way to repair rob
Door catches.
One of the latches may have broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Mar 01, 2011 | Bosch HMT8656GB Microwave Oven
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
D40 flash latch broken
it seems that the plastic latch which holds the flash unit down is broken. as this plastic part is not available seperatly the camera shop must be changing the complete top assembly, and thatswhy is quoting that ammount
Mar 20, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
1996 lincilon continental drivers door will not shut
The latch in the door is in the closed possition most likley or the latch is broken all together. Hold the door open pull on the handle. use a screw driver to unlatch the closed catch. it looks like a sideways w that closes in on itself around the striker on the door.
Mar 01, 2009 | 1996 Lincoln Town Car
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
