Question about Ge Medical Systems Medical
ECG PAPER DOES NOT ADVANCE
THE PAPER ADVANCE ROLLER DOES NOT ROTATE. THE PLASTIC GEAR ON THE ROLLER ROTATES WHEN THE LID IS CLOSED AND THE PAGE ADVANCE IS PRESSED.
THE ECG PAPER DOES NOT ADVANCE.
WHEN I OPEN THE LID, I CAN ROTATE THE PLASIC GEAR ATTACHED TO THE PAPER ADVANCE ROLLER AND THE ROLLER.
WHEN I TRY TO HOLD THE PLASTIC GEAR ATTACHED TO THE PAPER ADVANCE ROLLER, I CAN ROTATE THE ROLLER INDEPENDENT OF THE PLASTIC GEAR. I NEED TO USE MODERATE FORCE TO MOVE THE PAPER ADVANCE ROLLER INDEPENDENTLY OF ITS ATTACHED PLASTIC GEAR. WHAT IS THE SOLUTION?
    Scholar:
  • 157 Answers
Hello fbadin1, contact Marquette/GE with model # of unit and order the paper drive assembly. Been there do that. Merry Christmas.
Posted on Dec 05, 2008
Bpl ecg machine cardiart6108t
You can use a liquid plastic called Bondic, look for the channel on YouTube showing you how it works! YouTube.com/tombondic
Sep 09, 2013 | Medical
I Have a Schiller AT-102 ECG The problem is that the paper wanders out the paper sensor area and i get out of paper signal. The paper tray is 211 mm the paper size is 209 mm and no matter what i do the...
Hello!
I have the same model (Schiller AT-102) and unfortunately the same problem. I've tried almost everything with the hope of solving the problem: I changed the tightening springs which push the printer thermomatrix to the roller. Also replaced the optosensor. And so on... But nothing changed the situation. I would ask you to tell if you already have found the cause and the cure. Thank you in advance!
Jan 29, 2011 | Schiller Welch Allyn Cardiovit At 2...
Our hp laser jet 1320 has black lines running horizontally on the page. Is there something we can do to clear this problem up?
Get the toner cartridge out from the printer, move the plastic cover so you can se the light green roller. On both ends of the roller are gear wheels, use your fingers to rotate them and see if there is any toner on the green roller (lines). Check if there is some piece of paper or some dust or dirt on the roller, and if there is, gently wipe it with the dry soft cloth.
If the problem persist, try changing the toner cartridge.
Nov 05, 2010 | HP LaserJet 1320 Printer
Loading paper into the MAC 1200 ecg machine
1. Switch on the recorder
2. Pull up the handle of the paper door and fold it out
3. Remove the cardboard from the top of the new pad and place the pad, including the cardboard backing at the bottom and with the arrow pointing towards the unit, into the paper compartment
4. Pull the top sheet out of the compartment and guide it around the guide roller
5. Holding the leading edge of the paper in place between the two markers on the recorder, close the paper door. Ensure that it locks into place on both sides.
- When inserting an already started Z-fold pad, the grid side must face up and the first fold must point the compartment.
(You can find more information at MAC 1200 Operator's Manual, there page 59.)
Apr 19, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
Timing, jams or prints off bottom of page
Hi hotpress:
Try these steps.
Print transfer jams
1.
If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
seated.
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
SB467.
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
May 23, 2009 | Xerox Phaser 850 Printer
Printing (text suddenly blurry bold after closing lid).
open the toner access door remove the toner, slowly lower the tone access door and ensure that the top roller (charge roller) is lowering straight. the roller in the bottom of the cavity (the transfer roller) push down on this to ensure that it has spring tension. if the top one is level and the bottom one has tension then you'll need to change the high voltage power supply.
Jan 15, 2009 | OKIFAX 5780 All-In-One Led Printer
Paper jam is showing on printer info., but ther's no paper jam.
Ok this issue ussually occurs when the roller feed doesn't load the paper due to the following reasons:
1. If your printer is operating for  more than two years or so... gear tear will most likely to occur. If you can open the printer and check everytime the printer initiates after power on ad if the roller feed doesn't rotate but the leftmost rotary gear with the encoder wheel rotates, the gear is most likely to be loose even there is no paper jam nor dust contamination on the rubber and paper feed mechanism. You need to replace the said gear with the encoder strip . A simple solution would be aplying epoxy resin so it will be fixed on the rotary shaft. It may last for quite sometime but better yet replace the gear.
2. The feeder rollers might be dirty and needs to be cleaned and greased the gears.
3. Probable defective print cartridge. Try replacing it with a new one.
But based on the items above, if your printer is operating more than a year or two, and frequent paper jam is being experienced, gear tear near the motor is the culprit.
Dec 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon MP530 shows paper jam, when paper is not jammed.
First – diagnose your problem. In my case the first roller which feeds the paper through the ADF (under small black flip up cover on top) was not turning. Hence no paper advance and error claimed a paper jam (it wasn’t – just a failure to advance paper)
The cause turned out to be a stuck gear turning that silver rod at the top. A bit of household oil has worked a charm.
To get at the gear, unhinge the ADF cover retaining tie (black flexible plastic stopping it opening all the way). Just lift it up and roll over towards printer.
Then unscrew one screw next to that tie. Gently prise plastic cover off by lifting up from left hand side (near that black tie). It should rotate off. Keep power on and fingers out.
Put a few drops of oil on top gear. Place paper in ADF and attempt a batch scan operation. Gears should turn and lubricate parts. Repeat.  Once working, replace cover, screw and tie.
Mine had seized months ago and is now working fine. Hope yours does too.
P.S. Get a Continuous Ink System (as sold on eBay) - awesome for an ink guzzler...
Sep 08, 2008 | Office Equipment & Supplies
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Medical Logo
235 people viewed this question
Top Ge Medical Systems Medical Experts
Steven Clarke
Steven Clarke
Fred Murdock
Fred Murdock
Vuk B
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
