Question about Sony DVP-NC655P Multi-disc DVD Player
Player won't function
Hi, Player accepts discs, tray opens and closes with no problems. However, player will not play discs. When the tray enters the machine, it emits a number of strange sounds. There is an out of the ordinary hum, overlayed by a plastic scratching noise, lasting perhaps two or three seconds. The hum stops, then starts up again, but then the hum and scratching, while still overlaying each other and perfectly synchronous, become intermittent, as if something inside the machine were trying to focus, or adjust its position. This cycle continues for about half a minute, then the unit searches for another disc (it is a five-disc changer), and whether there are more discs loaded or not, the unit returns "NO DISC" in the display window, and none of the disc numbers in the upper left corner of the player are lit up. Oh, and when the unit is going from one tray to another in order, a high pitched squeal can be heard from the machine. When it reverses direction (i.e. when the "disc skip" button on the remote control is pressed four times and the tray travels in the opposite direction) there is no squeal. Any assistance would be greatly appreciated. Thanks. Nick
  • 1 more comment
  • TheMc Dec 02, 2007
    I have the same exact issue. Well, I guess the sounds are not as described, but same chain of events.
    Was there ever a solution offered? Did you ever figure this out?
    Any help would be greatly appreciated.
  • tdelio Jan 05, 2008
    Same problem, no squeal.
  • Anonymous Jan 29, 2008
    I have the exact same problem and do not want to have to replace the dvd player, but from what I've heard it's going to be expensive to fix any way you look at it. Try checking out http://altechllc.com/serendipity/ about the dvd player that could, perhaps it's just an inertia problem?. If you have any better solutions please post them, thanks.
    Sergeant:
  • 238 Answers
The Lazer is dirty open it take a ear bud then apply alcohol to bud wipe Lazer gently normally you can use nail polish remover to clean
Posted on Mar 03, 2017
3 Suggested Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
Tray timing is out of alignment, probably from tray being forced open or closed. Removed cover, removed screw from center of CD turntable, removed two metal clips holding sliding tray down on left side. I ejected tray assembly first and shut off power and unplugged unit lifted left side of tray and experimented with black gear that controls the lifting of disc and the ejecting and retracting of tray. Tried to adjust it to the ejected position as best as possible then powered up and retracted. Next power down and upplugged. Inserted a cd anywhere, note slot # plugged in unit turned on power. Watched disc indicator led's to calibrate with slot if the numbers don't match up, power down, lift up disc turntable to disengage from gear drive near center post and turn to align disc with laser and disc pickup and drive assembly. If tray is not in correct position too align with disc pickup and laser reader assembly lift left side of tray andmove on gear to addjust.
Posted on Aug 29, 2009
xptareq2000
  • 1447 Answers
SOURCE: Discs won't play.
please change laser unite then solve your problem
Posted on Sep 09, 2009
How do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
Jul 26, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Tip
Region free code for Zenith DVC2200 DVD player
Power on the player with no disk in the drive.
Press "PAUSE" on the remote.
Enter "3 1 4 1 5 9" on the remote (the word CODE appears on the display).
Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.).
Power the player off and then back on.
To play any region disc in these players shown below simply follow these instructions.
Open the tray, place an R1 disc on it but don't close it.
On the remote press 0, 1, 2, 3, PLAY.
The tray should then close, if not close it, and the player is now completely region free.
on Mar 07, 2010 | Televison & Video
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
I need to reset the region code on a samsung home cinema system HT-X200
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Thanks
Rylee
Sep 15, 2009 | Samsung Audio Players & Recorders
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Change region
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want("0" for free zone) . Next press open/close.
Sep 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Ate my CD
looks like the tray is offline so basiclly its not reading the first disc because its far away from the eye so by putting another disc in and it reads it because the eye is close enough to read it .  u may have to open the player up to get the first disc out.  good luck.
Oct 24, 2007 | Pioneer DEH-P690UB CD Player
Sony DVP-NC655P Multi-disc DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
