Question about Zenith C27A24T 27" TV
Airplane interference in converter box
We installed the converter box, our tv used rabbit ears. It works fine most of the time, except when a plane flies over the house (we are on the take-off/landing path for the SeaTac airport), every time a plane goes overhead, we loose the signal, the flow of images stops to then slowly update only a few squares of the screen at the time, giving us a broken, annoying image and we loose part of the program for anywhere from 10-30 seconds. It's like trying to watch a movie on-line on a computer when the connection is not fast enough and it has to stop, download more of the program and then continues, except that on TV you just miss the segment.
Anything we can do about that other then going satellite or cable?
  • Anonymous Jan 28, 2009
    We are also having this problem with the digital signals that our local stations are now broadcasting with. Thankfully most of our locals are using two signals at the moment (one analog and one digital) and, though the picture flutters on the analog when an airplane goes overhead, we can still watch the program. When digital-only comes around, television will be unwatchable as we get many planes throughout the day and night.
    Moving the rabbit ear antenna does nothing to help, I had considered an outdoor antenna up on the roof for a stronger capture of the digital signal, but then I figure that the cost and work of that setup, which may not even work, won't be worth it when the cable company is offering local stations (plus a few others) for $10 a month for the first year.
  • 20 Answers
Have you tryed moving the ant. to another place in the home? if it still does it you may need an ant. with a fm trap on it. this will get rid of some problems like this. hope this helps............
Posted on Jan 02, 2009
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
Want to set this up without cable. Someone told me to go to "air" mode and add rabbit ears and this will work. I cannot find an air mode on this tv. How do you set this one up with rabbit...
You will once again, purchase a converter box to receive an over the air channel. I don't think you will have to really worry about using an over the air mode on the TV. It may be in the menu, but will work otherwise after being placed on channel 3 to receive through the converter box. The rabbit ears will be connected to the converter box itself.
Feb 13, 2011 | Televison & Video
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Digital to Analog Change Over
you are fine. if you do not get a pic or sound it could be that the rabbit ears you are using are not compatable with your box. you may need a diff. type of rabbit ears
Dec 30, 2008 | Zenith C27A24T 27" TV
DIGITAL CONVERTER BOX
If you have Cable, or sattelite tv, then no. Or if you if the rabbit ears and the tv has a digital tuner no. but rabbit ears and an anolg tner then yes.
Oct 26, 2008 | RCA F27442 27" TV
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Magnavox TB 100 MW9 STB Converter Boxes I'm trying to solve the antenna/rabbit ear connection from this converter box to the t.v. I only get a pic when the rabbit ears are connected to the back of the...
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Jun 11, 2008 | Televison & Video
Zenith C27A24T 27" TV Logo
436 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
