Question about Sharp Microwave Ovens
Need to put new latches in door model R-1480 - Sharp Microwave Ovens
  • bnrjo Nov 23, 2008
    Thank you infomation was great ,got it fixed
  • Sharp Master
  • 9,098 Answers
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
Posted on Nov 23, 2008
The door latches wont latch
Door catches.
One of the latches has broken off and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 03, 2011 | Sharp R-1480 Microwave Oven
I have a problem with my Sharp Carousel R 1480. The door will not latch and the light will not go out. The hooks on the actual door seem to be in place and working like normal so Im assuming it is...
We have the full service manual at our site here.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
In some cases, you problem may be a damaged latch head, which is an odd name for what I would call a door switch holder.
Our file on door switches is here.
You can order parts from Encompass Encompass here or you can call them toll-free at 866-779-5835.
Oct 01, 2010 | Sharp R-1480 Microwave Oven
Hoe to disassemble the door to get access to the
Since you posted this under the R-1480 category, maybe yours is an R-1480? If so, here is the service manual.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 31, 2010 | Sharp R-1480 Microwave Oven
How do i take the door apart to replace the latch spring on my sharp carousele r 1480
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jul 09, 2009 | Sharp R-1480 Microwave Oven
Replacing a latch spring on a sharp r-1480 microwave
THE RELEASE BOTTEN ON SOME MODELS CAN BE TANEN OFF AND THE SPRING IS RIGHT BEHINDPRY OUT OF GROOVES PUT IN SPRING ANGALIGN BOTTEN UP AND REPLACE
Dec 07, 2008 | Sharp R-1480 Microwave Oven
Door latch on sharp 1480 microwave over the range oven
You will need the free Acrobat Reader to view or print it.
Sep 13, 2008 | Sharp R-1460 Microwave Oven
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Aug 08, 2008 | Sharp R-1480 Microwave Oven
Door Doesn't latch shut
Usually it's not thespring but instead the "latch head", which has a little loop on the backside to hold the spring. The loop breaks off.
The latch head is the long plastic piece with two protruding hooks which activate the hidden door switches.
The door will need to be taken apart (but not removed from the oven!) to get to the latch head. See the attached example photo.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Sharp R-1480 Microwave Oven
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
